Sponsored by: Real Truck
Dvd not working.
Old Oct 8, 2018 | 08:44 PM
T Mos's Avatar
T Mos
Dvd not working.
I have an 06 f350 and put in a dvd player. Didn't have the mounting bracket so it sat In the hole in the dash. Attached the harness and just taped it. No problems. Got the bracket to I soldered the harness and isntalled it. No power. The 2 fuses that say radio are fine I think 11 and 32. Fuse on the dvd player is fine. Re did connections for ground and the yellow 12v reads 12v. The 12v battery is good. The red reads nothing on the voltmeter and I can't figure out why I don't have power. Is there another fuse or another wore I'm not seeing?
Old Oct 9, 2018 | 01:14 PM
T Mos's Avatar
T Mos
K thanks for the help I'll just go **** myself🤣
Old Oct 10, 2018 | 04:49 PM
Fefanatic's Avatar
Fefanatic
Well, I just saw this but I won't go **** myself. If you have power to all fuses then you need to remember that the power needs a return to ground. Ground the radio to a good ground point under the dash. It sounds like your ground wire is not spliced correctly.
Old Oct 11, 2018 | 06:46 AM
T Mos's Avatar
T Mos
Thank you kindly I'll try to check that one out again. (It was me who was to **** myself, you gentlemen don't owe me anything but the advice is appreciated)
Mitchel Wincentaylo
Mar 27, 2017 12:12 AM
leinhit
Jul 29, 2012 08:34 PM
Johnnyboy04
2004 - 2008 F150
Oct 15, 2004 09:56 AM
00 Nav
Mar 27, 2004 05:13 PM
Bargod
Jan 16, 2004 05:53 AM
