Algae in fuel?
Old Sep 28, 2018 | 08:07 PM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
Algae in fuel?
Changed my fuel filter and this is what it looked like. Has a film on it when you wipe the filter pleats. I've never experienced oil or algae but have read algae is slimy which this is. Have always got fuel at a truck stop to eliminate bad fuel.
The black spots on the concrete came out of the filter and dissolve when you touch them.
When looking in the fuel bowl what I thought was dirt is actually the same thing as the black specs above.
Any ideas?
Old Sep 29, 2018 | 07:31 AM
867.309's Avatar
867.309
That is one black, nasty looking fuel filter. Thanks for the pictures. I like to see stuff like this. I hope you post what made it that way when you find it.
Do you have software to check your high oil pressure and IPR duty cycle? Just curious if it would show up there?
Do you have an inspection camera you could snake down into the fuel tanks to look for algae or gunk?
Old Sep 29, 2018 | 08:18 AM
'74 Ford 250 CS
I've never pulled one to look this bad. Never had oil in fuel so not sure if that causes a film on the pleats or not. Figured oil would be more absorbed into the filter.
The only thing I have to check it is a scanner at work. It has run well, on issue is randomly the engine vibration felt on the floor. It could be the down pipe but now not sure if the filter was prohibiting flow causing the engine to not run well. The other day when pulling the truck out of the garage to put the car seat in, I could hear a engine knock that went away after driving. I couldn't hear it in the truck. I asked my brother and he said it could be a injector knock. Now wondering if it's related to the filter?
I'm going to buy some Power Service Biocide and clear diesel to see if that helps.
I'll have to ask the mechanic at work if he has camera scope.
Old Sep 30, 2018 | 08:17 AM
tjc transport's Avatar
tjc transport
i ain't rite
oil in the fuel will normally not clump up like that, it will just dilute and become one with the fuel.
that does look like algae contamination to me.
Old Sep 30, 2018 | 07:57 PM
'74 Ford 250 CS
I'll update after I run through a tank. I've put the power service stuff in so we'll see if it helps. Guess I need to get another filter as well.
Old Oct 1, 2018 | 07:55 AM
knottyrope's Avatar
knottyrope
mine didn't look that black or have particles when my injector orings were bad
Algae can be kept under control with some additives and a spare filter is a good idea incase it plugs up
Old Oct 10, 2018 | 11:50 AM
'74 Ford 250 CS
Update. Here is my filter after 50-60 gallons of fuel. Treated the fuel a second time on second full up. Problem seems to be corrected. Name:  photo365.jpg
At higher RPM's, I don't feel the floor vibration as much. I believe the filter was causing some of not all of the problem.
On the way to Tennessee,pulling our trailer, all went well.
Old Oct 11, 2018 | 08:27 AM
knottyrope's Avatar
knottyrope
that looks much better
I bet the clogged filter was starving the engine when more fuel was needed.
did you clean the screen in the bowl? don't look like enough fuel is in the bowl.
screen is right below your thumb in the pic, take a q tip and swab away the gunk
Old Oct 14, 2018 | 01:20 PM
'74 Ford 250 CS
Sorry just got back from our camping trip and we had very spotty service.
I had drained the bowl a little to keep fuel going everywhere. That's why it's drained down a little. Thanks for the advice on checking the screen. I forgot about that. I'll check and report back.
Byram
6.2L V8
Feb 24, 2012 06:27 PM
theenforcer
Jun 6, 2011 02:11 PM
ETKMS
6.4L Power Stroke Diesel
28
May 5, 2011 08:49 PM
Bigcat350
17
Dec 29, 2009 10:03 PM
Spooky
16
Dec 12, 2004 04:49 PM
