Help me read this transmission dipstick
Pictures:
https://imgur.com/a/EwrDw0w
I stuck it all the way in, with the engine running in park, hot.
I'm having a hard time deciding if it's full or not. The transmission slipped while driving a couple of times, making me think it's low on fluid. But I don't want to over-fill.
What do you think?
Steve
What do you think?
Steve
I know on a Ford passenger car (I'm referring to RWD) the fill tube is usually straight and accurate readings are easy to see but on a van where you have a long fill tube with a curve or two you're not likely to get an undisturbed sample for reading.
How has GM or Dodge gotten around it?
I'm fairly sure Ford changed the trans dipstick to accommodate the construction of the E-Seiries which wouldn't really allow a straight-up tube. Add to that most people wouldn't bother checking the trans fill level if the tube wasn't conveniently located up front of the engine bay.
When checking my own with the white plastic tip I follow Mark Kovalsky's advice when and how to check the fluid level. As long as the fluid is showing on the cross hatched portion of that tip I'm good. I prefer running the fluid to the top of that mark but I don't check it every day either.
Also if a transmission slips there might be another issue presently or about to present itself at the worst time---if it does that again maybe have a trusted and qualified mechanic check it out.
BTW Steve if I missed it I'm sorry but it's always helpful listing your year, model and engine when starting a thread---engine size and fuel too are good things to know for us trying to help. Good luck with that slipping thing---hope its nothing serious.
You can't tell the difference between a dry portion of the dipstick and a portion that has fluid on it? If not, there is no way I can help you. Read what I wrote. I didn't use the word "undisturbed." I said to look for the lowest dry point on the dipstick.
Because as described above it won't fit. The transmission is too far back..
You probably didn't notice, but a Caravan is front wheel drive while the E-Series is rear wheel drive. So in the Caravan the entire transmission is in the engine compartment. The transmission in the E-Series is MUCH further back. If the stick came straight up it would be between the seats. Most people don't seem to want the dipstick next to the inside the van.
After you've poured 14 quarts of fluid down the tube, the whole plastic tip is smeared with fluid after shoving it down the hole and pulling it back out. In order to see anything, you'd have to drive it around and get it nice and hot to allow the fluid adhering to the walls of the tube to run down into the pan. Checking it after it sits for a day or so, then yea, you might be able to tell where the level is on that plastic but not otherwise.
rogersdan
08-02-2013 02:56 PM
