Distributor Part Number
Old Sep 28, 2018 | 11:45 AM
stm76's Avatar
stm76
Does anyone know what the distributor part number is for the 1963 Ford Econoline Travel Wagon? I found something for a 65 that said a part number of: D3DF12127HA but need to know if this would be the same for the 1963?
This forum is pretty awesome by the way. So grateful for all the help everyone is willing to give. You all will probably be sick of all my questions by the time I'm done asking.
Old Sep 29, 2018 | 05:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I found something for a 65 that said ID engineering number: D3DF-12127-HA but need to know if this would be the same for the 1963?
There are no part numbers marked on parts after 1956, just casting or ID engineering numbers, when applicable.
This is the ID engineering number for a 1974 Maverick/Comet 200 I-6 distributor w/a M/T, the part number is D4DZ-12127-H (Motorcraft DA-1377).
What size engine, type of trans does the 1963 Econoline have?
Old Sep 29, 2018 | 06:04 PM
KULTULZ's Avatar
KULTULZ
Post
NOTE-
FORD used the LOAD-O-MATIC dist on in-lines until the 1968 model year, A later dist will allow you to have better performance but you will also need a 68/ carb to match the dist.
Just a thought.
Old Oct 1, 2018 | 01:32 PM
EmilBarnabas's Avatar
EmilBarnabas
Stm76, we need to know what engine you have. If stock, it should be a 144 or 170. My guess on a Travel Wagon would be a 170.
This is might help you figure out which size you have.
Econoline Engines
Old Oct 1, 2018 | 04:37 PM
EmilBarnabas
For 1963 Econoline
170 engine - distributor part number is C2UZ 12127-A, which was replaced by C3UZ 12127-B.
This is the same for all 1962-1964 Econolines with 170 engine and manual transmission.
If it has a marking on it anywhere, it might be identified as C2UF 12127-A, C2UF 12127-B, C2UF 12127-C, or C3UF 12127-D
144 engine - distributor part number is C3UZ 12127-A
If it has a marking on it anywhere, it might be identified as C3UF 12127-E
Here is an exploded diagram of the Loadomatic Distributor for all 1961-1967 Econolines with the 144 or 170 engine.
http://econoline.org/drawings/P-2961.png
GJCAT
Large Truck
17
Feb 21, 2018 12:53 PM
corvair62
Apr 24, 2017 06:45 PM
armashby
Nov 2, 2016 09:20 AM
Doubleclutch
Jan 23, 2016 09:01 AM
htrdr
Mar 27, 2011 04:14 AM
