Number Dummy, need part numbers for - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 12-03-2017, 08:46 AM
GJCAT GJCAT is online now
GJCAT is starting off with a positive reputation.
A 65 F600 300 I6 frt motor mount. This is the rubber biscuits and sleeve. Reference #6068, Also who may have them. Thanks
Old 12-03-2017, 03:16 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
1) C1TT-6A027-B .. Sleeve / Obsolete
GREEN SALES CO. in Cincinnati OH has 43 = 800-543-4959.
1) C1TT-6A061-C .. Lower Front Insulator / Obsolete
GREEN SALES CO. has 2.
OBSOLETE RELIABLE PARTS in Nashville GA has 3 = 229-686-5101.
1) C3TZ-6068-D .. Upper Front Insulator / Obsolete
GREEN SALES CO. has 175.
Old 12-05-2017, 06:02 AM
Bill one other number I need to find Reference #6068 rear mounts between the bell and the frame for the 65 truck 6 cylinder engine. Thanks
Old 12-05-2017, 07:04 PM
Notmeofficer's Avatar
Notmeofficer Notmeofficer is online now
Notmeofficer has a good reputation on FTE.Notmeofficer has a good reputation on FTE.
Jumping in here because I have a number of these trucks..67-79 300s
Anchor makes them (and a number of others).. I get mine directly thru oriellys.. special order.. but they are cheap.. Ford also used them in other applications as well.. I believe you can get anchor from summit racing.. very cheap..Ive been trying to cross reference the part number by picture...
There is an on-going thread from bill that is the parts thread
https://www.ford-trucks.com/forums/1...y-info-44.html
Old 12-06-2017, 06:41 AM
Thanks for the info. Is there a parts CD for these trucks?
Old 12-06-2017, 07:08 AM
Yes..I found mine on eBay...along with original Ford factory manuals..iirc the CD was like 39.00...the manuals..a full set were like 150.00
Old 12-07-2017, 01:19 PM
Bill one other number I need to find Reference #6068 rear mounts between the bell and the frame for the 65 F600 300 I-6.
2) C1TT-6A027-B .. Spacer / Obsolete
MILLER OBSOLETE PART in Binghamton NY has 4 = 607-722-5371.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 20 = 800-476-9653.
2) C4TZ-6A061-A .. Lower Rear Insulator / Obsolete
CARPENTER NOS OBSOLETE PARTS has 1.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
2) C5TZ-6068-E .. Upper Rear Insulator / Obsolete
MILLER OBSOLETE PARTS has 1.
1964/72 Ford Truck Parts Catalog available on a C/D from hipoparts.com
Old 12-14-2017, 09:39 AM
I have an email into anchor industries
I believe anchor ani-2048 and 2050 may be the same motor mounts (listed for earlier applications). I am asking them for the physical dimensions..
.. the above mounts are a couple of dollars through Summit.. here's hoping
Follow up email from ANCHOR Industries
Anchor said they dont list F600s specifically but said look at the above mount as well as this one
its slightly larger than the one above... ani-2014
The reason these are worth following up on is cost.. these are in the 3 dollar range.. all the NOS ones are three to four times and more of that price.
Im going to order one of each..Ill update my results
Old 12-14-2017, 11:57 AM
Bill.. when I run these number they pop up for a lot of other trucks other than F600s... including light duty.. if this is true then these mounts are available potentially new.. but Im still a little confused.. are these also spec'd for a bunch of light duty fords in the 60s?.. can you tell?
For example.. these guys
https://www.steelerubber.com/motor-mount-20-0597-11
Thank you
Old 12-14-2017, 02:34 PM
Quote:
if this is true then these mounts are available potentially new.. but I'm still a little confused.
Are these also spec'd for a bunch of light duty fords in the 60s?.. can you tell?
Of course!
Thank you
If I listed all the applications for these puppies, it would take me...at least...several hours.
I didn't list any of the applications, just listed the part numbers for the OP's application ('65 F600).
Here's the pages from the 1957/63 truck catalog for 272/292 front & rear motor mounts. Do some of these part numbers look familiar?
Old 12-14-2017, 07:03 PM
I got it bill,,sorry my friend
But what you did provide was confirmation that the Anchor aftermarket ones 2048 and 2050 ARE CORRECT by application.. and as such Im ordering them.. this is a gold nugget find because they are new.. and cheap compared to green sales or carpenter..
Santa will be generous to you..as he should
Old Yesterday, 06:15 AM
This info will get me the parts I need for the rear mounting. Many thanks to you both. we had several of these f 600 I6 trucks around yrs ago and a lot of them ended up in a local truck yard. The owner of the yard died about 5 yrs ago and as usual the yard got cleaned out. Tanks again.
Old Yesterday, 07:08 PM
GJCAt
I got the anchor motor mounts today... they are too small.. they would fit the light duty 300s...
Im still searching
56 ford serial number Mike Whatley 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 11-05-2017 09:53 PM
cylinder number order johnno5 6.2L V8 3 11-17-2016 05:13 AM
For Number Dummy GeneGregory 1973 - 1979 F-100 & Larger F-Series Trucks 18 11-11-2016 09:40 PM
Part number homertwo 1999 - 2003 7.3L Power Stroke Diesel 12 04-29-2016 12:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
