Rear Differential Torque Values?
Old Sep 28, 2018 | 09:01 AM
EViS's Avatar
EViS
I have a 3.55 LSD 8.8" rear diff on my 2004 (04-08) Ford F150. Unbelievably the 10 bolts which hold the Ring Pinion in place have loosened (one having sheared off, one fallen out and a handful bent whilst still fully threaded)! I'm hoping the only serious damage that was sustained was a damaged diff cover and that everything will keep running. So, I've ordered some new bolts for the ring pinion, but need to know the torque values for these? Also, what should the toque be for the bolts holding the diff cover in place?
Old Sep 28, 2018 | 10:49 AM
85e150's Avatar
85e150
That axle is scrap. You need a rebuild if not a whole new setup.
Old Sep 28, 2018 | 11:22 AM
EViS's Avatar
EViS
What makes you say that? Care to expand a little please?
Old Sep 28, 2018 | 07:03 PM
85e150's Avatar
85e150
Once you have breakage like that everything is questionable. How long did it run like that? Was it worked on recently? How much noise and for how long? If it ran any time at all, the gears would be worn "funny". If it was worked on recently consider all work done to have been done wrong. If it was making noise and especially if it was doing so for any time, it's junk.
Old Sep 29, 2018 | 09:03 AM
EViS's Avatar
EViS
It ran like this for approx 6 miles (driving slowly, mind). I've owned the truck for 4 years, and the diff has never made any odd noises or given any trouble. Would you not even bother re-torquing new nuts and giving it a go?
Old Sep 29, 2018 | 10:06 AM
85e150's Avatar
85e150
So it was just worked on?]
Old Sep 29, 2018 | 07:08 PM
xlt4wd90's Avatar
xlt4wd90
Just looking at the chunks of metal missing from the parts I can see, I'm guessing that there are shrapnel spread throughout the casing. And to remove the remnants of those broken bolts from the ring gear, you will have to pull the differential, which means you're not that far from rebuilding the whole thing anyway. Why take the chance with re-using the old parts?
Old Sep 30, 2018 | 01:13 PM
EViS's Avatar
EViS
Not in the time I have ever owned it, no.
Old Sep 30, 2018 | 01:16 PM
00t444e's Avatar
00t444e
60 ft lbs according to this, Differential Installation Instructions | West Coast Differentials
Old Oct 2, 2018 | 04:58 PM
mark a.'s Avatar
mark a.
It might be alright. I would tear it down, clean and deburr anywhere it got hit. Get it back together and slowly turn the yoke while putting some resistance on the ring gear, feeling for any resistance anywhere.
rlh68050
Jun 25, 2009 08:49 AM
mpluxton
Nov 1, 2006 05:34 AM
sillyp
Sep 15, 2004 06:46 AM
JeremyH
1997 - 2003 F150
Jun 24, 2003 07:22 PM
AlwaysStuck
Oil & Lubrication
Jan 29, 2002 04:52 AM
