Wrong fluid in a 4r70w
Old 09-25-2018, 03:02 PM
Roll Tide Roll's Avatar
Roll Tide Roll
Roll Tide Roll is offline
I recently rebuilt the 4r70w transmission in my 03 f150 supercrew. Realized later that I probably put the wrong fluid in (I just used generic atf, said it was good for dexron and mercon transmissions). I guess it's supposed to have mercon v. Is there anything I can do, short of having the tranny flushed, to make sure I don't ruin the brand new parts? It seems to drive fine, other than being late on the 1-2 shift. (That might be the accumulator spring).
Old 09-25-2018, 06:29 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
a 2003 probably does not have a drain plug in the converter, so you will leave 8 quarts of oil in the converter if you pull the trans pan and take that 5 quarts out........... one option is to remove the trans outlet tube that goes to the radiator and point it into a bucket.. start the truck and pump out 3 quarts... stop and refill 3 quarts.... start truck and pump out 3 quarts... stop and refill 3 quarts.... repeat a few times... This is not ideal, but you should get a good portion of the MERCON V into the system... If the ORIGINAL oil you put in is actually a MERCON equivalent, then your not in too bad of shape.. Earlier transmissions used the MERCON and was later upgraded to the MERCON V.
speedracer2012
1997 - 2003 F150
06-15-2012 07:55 PM
96f150
03-24-2011 09:42 AM
advocate
1997 - 2003 F150
03-18-2007 05:50 PM
blueeyes2478
04-09-2006 02:49 PM
Kenny Bonnell
1997 - 2003 F150
06-24-2005 10:58 AM
Quick Reply: Wrong fluid in a 4r70w
