2005 4x4 F250 6.0
Throwing code P1876
Car intermittently will put itself into 4Hi and the 4x4 light will come on. The switch can be in 2wd and it will switch itself to 4hi sometimes. Sometimes it drives completely normal. When the truck put itself into 4hi then the switch will not work into switching it back into 2wd or 4lo. The light is showing when it switches itself into 4x4 however the switch will still be on 2wd. Also when it switches itself into 4wd the air will blow out the defrost. Any idea what the issue could be or best way to diagnose the issue?
Thank you for all the help.
Sounds vacuum and electrical related. I would check all the connections to the tcase and transmission for bare wires or loose connections. I would also check around for a vacuum leak as the defrost coming on in 4wd is a common sign of a vacuum leak
Without being able to do any hands-on troubleshooting it sounds like it might be a faulty ESOF switch (on the dash). It controls the shift between modes and the rest of the system just follows suit. Since the whole system goes into 4wd that's the only common point I cant think of off the top of my head.
As for the defrost that's definitely a vacuum leak as 02TB250 said. If your ventilation operates normally and only goes to defrost when you are going into or out of 4wd then it is somewhere in the ESOF portion. That trail starts at the vacuum hub pulse solenoid and goes all the way to the hubs.
Basically your ESOF signal opens the pulse hub solenoid allowing vacuum to be felt through the lines to the hubs. The hubs (now with vacuum) "suck" the auto-locking hub and lock it. After about 30 seconds or so the solenoid shuts and your hubs are locked. When you go to 2wd the same thing happens and the auto-locking hub unlocks. Similar in concept to a ball point pen. Click the top once and the point comes out. Click it again and the point retracts.
Common fail points are the vacuum lines cracking, the vacuum line connection at the hub, and the o-ring/seals for the hub. Less common issues are the vacuum hub pulse solenoid and the auto-locking hubs.
I heard that they made improvements to the ESOF in '05 that made it better than mine. I recommend cruising over to the 6.0L forum and searching/posting your issue. I'm sure you are not alone.
Still have not fixed this problem. Any other input would be great. Mechanic is thinking could be the GEM but in 2005s its built onto the cluster which would mean that would need to be replaced or fixed. Does anywhere fix the GEM on 2005 clusters?
Mechanics who don't troubleshoot almost always blame the GEM first. Proceed if you want to waste your money and not fix your issues. I would find a new mechanic if this truck was mine.
Find and fix your vacuum leak first.
The T Case solenoid failure isn't a difficult item to fix. It is almost always the solenoid, the switch or the wiring harness. Simple troubleshooting with a volt meter or test light will pinpoint the location.
A 2005 Super Duty doesn't have a GEM module and the instrument cluster doesn't have anything to do with the 4X4 system except for having the indicator light bulbs in it. It has a module that is dedicated to the 4x4 system called, not coincidentally, the "4 X 4 Control Module" that serves as the controller for the system. If your mechanic doesn't know how the system is supposed to operate, you need a different mechanic.
Did you ever follow up on the P1876 DTC? The factory service manual has specific diagnostic information if that code is present.
