Hello everyone, I been reading the forums for a long time and finally made a account, this place is a unbelievable wealth of knowledge and I am lucky to have found it. I have a 68 F600 grain truck that I have had for about 6 years and have a good amount of play in the steering and king pins. I haven't had much luck with parts houses finding parts for me. I am trying to find a king pin set, drag link and tie rod tube and tie rod ends. All help is greatly appreciated. Also would anyone have a wiring diagram? I recently picked up a 1972 F600 dump truck that the wiring is very badly band-aided together and the mice have had a lot of fun with also. Thanks again
Hello everyone, I been reading the forums for a long time and finally made a account, this place is a unbelievable wealth of knowledge and I am lucky to have found it. I have a 1969 F600 grain truck that I have had for about 6 years and have a good amount of play in the steering and king pins.
Please ask further questions in the LARGE TRUCK forum. Most members of this forum have pickups.
Last 6 digits of the VIN: F59357 = This is a 1969 .. not a 1968! (1969 serial number range: D82,001-G30,000).
Your '69 F600 has the standard equipment 5,000 lbs. capacity front axle, because the AXLE code (F3) does not have a 3rd digit that would be related to an optional front axle over 5,000 lbs.
C3TZ-3111-A .. King Pin Kit / Obsolete
BOSS MOTORS in Marysville KS has 1 = 800-453-3696.
OBSOLETE RELIABLE PARTS in Nashville GA has 2 = 229-686-5101.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 15 = 800-476-9653.
------------------------------------------------------------------------------------- C7TZ-3A130-D .. Tie Rod End - Right Hand Tube Thread / Obsolete
CARPENTER NOS OBSOLETE PARTS has 9.
GREEN SALES CO. in Cincinnati OH has 33 = 800-543-4959.
-------------------------------------------------------------------- C7TZ-3A131-D .. Tie Rod End - Left Hand Tube Thread / Obsolete
GREEN SALES CO. has 6.
CARPENTER NOS OBSOLETE PARTS has 15.
------------------------------------------------- C9TZ-3281-A .. Spindle Connecting Rod Tube (1969/72 is different than 1967/68) / Obsolete
No Ford dealer or obsolete parts vendor has any.
------------------------------------------------------ C7TZ-3304-A .. Draglink / Obsolete
CARPENTER NOS OBSOLETE PARTS has 3.
btw: You should be able to get allthese parts from NAPA
Thanks Bill, that helps me out a ton. I will have to get some parts ordered. Yep you are correct it is a 69, I have been super busy and my brain must have been in a couple different places when typing lol.
