6.2L V8 Discuss the 6.2L V8
Looking for a replacement 6.2
Old Sep 23, 2018 | 09:02 PM
Baku's Avatar
Baku
Hi guys,
Well it looks like my 2015 6.2 is on it's last legs, oil consumption going up and it clatters like a diesel when warm. Had a hard early life, looks like the previous owner mistreated it. Only has 130k km. Pretty bummed but learned my lesson about not having a pre-purchase inspection done.....
It's a great build though (Supercrew shortbox XLT with almost all the options, rigged up for a truck camper) so I've decided to keep it and swap the engine.
Does anyone know of a good source for documented low-miles 6.2s in the PacNW? Would need the name of a good shop in the Tacoma-Seattle area too that would be able to do the work. Got some early pricing in for $7k swapped on a used one which seems way too high to me. And new comes in around 10k.....
Cheers
Old Sep 24, 2018 | 05:06 AM
T diesel's Avatar
T diesel
https://parts.autonationfordwhitebea...gtZmxleA%3D%3D
It's a 2015. don't screw around.
Old Sep 24, 2018 | 07:54 AM
Ron94150's Avatar
Ron94150
Before putting a new motor in, pull the valve cover. We have a 2015 here at work that was burning oil big time. The oil was never changed in it, due to a old lazy truck shop employee that was about to retire and was fudging paperwork. They were in the process of changing perfectly good valve seals when I told them to check the pcv baffles. Sure enough, the drain hole in the baffle was clogged with sludge. It was sucking oil in the pcv system. Check all the rocker arms and valve springs while your in there. There was also a batch of valve covers with defective baffles. There is actually a TSB for this.
I would make sure it isn't just a timing chain tensioner making your noise as well. I've yet to hear of a bottom end failure on a 6.2. Now if you ran it dry if oil, that may be a different story.
Old Sep 24, 2018 | 08:17 AM
dnewton3's Avatar
dnewton3
2x ...the above is good advice.
Check the PCV system before condemning the engine due to oil use.
The noise might be a broken valve spring; rare but not unheard of. Tension-er as well.
Probably far cheaper to repair these issues than what you might think.
However, if you do indeed really need a different motor, I'd say spend the cash (if you have it) and get a good reman unit from Jasper or other source. Given the relatively new age of the truck, and presuming you'll want to keep it a long time, I'd not get some junk-yard engine. Reman'd engines come with pretty good warranty coverage; often better than OEM. Jasper is 3 yr/100k miles!
Old Sep 24, 2018 | 06:45 PM
Baku's Avatar
Baku
Hi guys,
Thanks alot for the advice and links, will start looking for cheaper new or reman options, any other links would be appreciated if you can think of 'em. That warranty with Jasper is a big draw, I will check with them. I changed the PCV last June, and the valve covers were done under the TSB a year ago, no change and the oil use continues to get worse.
Clattering noise starts up only after it warms up, not noticable when cold. I'm thinking probably not springs or tensioner on that account, but maybe viscocity has an impact. Was thinking it was a cam phaser but they seem to have fixed the issue on the 6.2 relative to the 5.4. And would probably be throwing codes, which it is not.
Will pull the valve covers and check around. Only other symptom I can think of is that is sometimes burns a bit of blue at start-up after it has been parked downhill, nose down, overnight. Otherwise if parked level, I never notice any blue smoke at start-up. Maybe a valve guide is done at the front of the engine?
Thanks again for your help
Old Sep 24, 2018 | 07:56 PM
Flatbed Ed's Avatar
Flatbed Ed
A reman motor from Ford cost about $4,000 or so and comes with A3 year unlimited mileage warranty that is your best bet
Old Sep 26, 2018 | 02:23 PM
ibdagriz's Avatar
ibdagriz
There was a guy here back in May who hauled a bunch of stuff to the scrap yard as he couldn't sell it. A relatively newish 6.2L motor was in there too.
All about timing I guess.
Griz
Old Sep 26, 2018 | 03:46 PM
SnowPlowDriver's Avatar
SnowPlowDriver
Salvage yard near me has several 6.2s. Range in price from $1700,465k ro $3700,51 k
wouldn't be practical for you but gives you an idea what they go for.
Old Sep 26, 2018 | 07:37 PM
Ron94150's Avatar
Ron94150
And you know that truck was running when it was wrecked. That's how I look at salvage yard motors.
Old Sep 28, 2018 | 10:36 AM
ibdagriz's Avatar
ibdagriz
I got a tad over 125k on the V-6 I dropped into my 06 Charger a couple of years back. Had 30k on it when I pulled it from the junk yard car it was in.
Guy's son I sold it to burned it up by not checking fluids on it in over two years.. LOL..
I had only $1500 in it all in after installing it.
Griz
eenyok
15
Feb 20, 2017 03:00 PM
dgwelsh
6.2L V8
28
Apr 12, 2016 08:26 PM
matpasch
Aug 27, 2009 01:03 PM
re-engineered
Oct 15, 2003 08:25 PM
bigbill89
Oil & Lubrication
Jul 22, 2001 09:07 PM
