After Market Heater System Recommendation?
Old 09-22-2018, 10:57 AM
Jpegg01's Avatar
Jpegg01
Jpegg01 is offline
So previous owner literally ripped every heater component out, truck was originally AC truck. So I need to install a heating system and was looking for recommendations. I know I could buy one from part truck or salvage yard but was thinking an aftermarket heater may be better than an original I know the aftermarket AC unit are a great deal better than the original
Old 09-22-2018, 12:19 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,128 Likes on 1,812 Posts
I have never known a stock heater, car or truck, not cook you out if the core not plugged.
Well maybe a VW bug heater but then how hot can an air cooled motor get in winter?
Now I don't know about you year trucks but the 80-86 trucks have different firewalls between AC & Non-AC trucks so something to look into if going with stock parts.
Dave - - - -
Old 09-22-2018, 12:28 PM
niko20's Avatar
niko20
niko20 is offline
Did he rip out all the venting ductwork too? Crazy if so
Old 09-22-2018, 12:34 PM
Jpegg01's Avatar
Jpegg01
Jpegg01 is offline
Yes everything gone, Even covered up a couple vent holes that I will have to remove the metal patch he used to cover up the vent holes just so I can put replacement vents in
Old 09-22-2018, 02:22 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
There's more than one type of A/C in these trucks.
Did the truck originally have factory installed integral A/C (combined with the heater) or deluxe dealer installed A/C (combined with the heater)?
Factory A/C: A/C controls are in the same panel as the heater controls, has the huge evaporator case at the right rear corner of the engine compartment.
Deluxe Dealer installed A/C has two A/C switches located in the HUGE dash bezel that sweeps across the entire right side of the dash.
If factory A/C, you'd be better off finding a 1973/79 F100/350 or 1978/79 Bronco with just the heater only or Economy dealer installed A/C (not combined w/the heater)...and use all the parts.
Old 09-22-2018, 02:32 PM
Jpegg01's Avatar
Jpegg01
Jpegg01 is offline
I dont know since all was ripped out. The passenger side engine compartment had a big patch in firewall where AC box was.
Old 09-22-2018, 02:43 PM
NumberDummy
The passenger side engine compartment had a big patch in the firewall where AC evaporator case was.
Factory installed integral A/C
Old 09-22-2018, 10:18 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,318 Likes on 2,468 Posts
Old 09-23-2018, 12:11 AM
84espy's Avatar
84espy
84espy is offline
If you are going this route, be prepared for some fabrication. Do you still plan to use vacuum control? How will you connect the ducting, run the heater hose, etc. Think it through. Here's mine. It still works great and I stay cozy in the winter.
https://www.ford-trucks.com/forums/1...ng-my-way.html
Old 09-23-2018, 08:36 AM
77&79F250's Avatar
77&79F250
Old 09-23-2018, 09:45 AM
5851a's Avatar
5851a
5851a is offline
I would look for a truck without AC if you just want a heater, remove it all along with big enough piece of firewall. Not saying that there might not be one somewhere, but the aftermarket units even with ac don't have fresh air intake. If your in humid cool/cold climate your going to have fogged up windows. It was a big advance when Ford brought out the Magic Air heater.
Old 09-27-2018, 11:48 AM
84espy's Avatar
84espy
84espy is offline
Fortunately, for me, California has low humidity and mostly mild winters where I live. Per your post, though: Wouldn't opening the fresh air intake in humid areas also leave you with fogged windows after setting a while?
Old 09-27-2018, 05:07 PM
5851a's Avatar
5851a
5851a is offline
Not sure in California but around here a lot of humidity in summer and winter brings snow from shoes into car and with the heater on it evaporates and condenses on cooler surfaces like glass. The aftermarket can't be all that bad though, I think it depends on your location and weather.
Thunderhorn
11-09-2015 09:17 PM
77f2504by4
27
06-24-2014 01:39 PM
blumax
06-07-2011 08:50 PM
frty7ford
02-08-2005 02:23 PM
Quick Reply: After Market Heater System Recommendation?
