2009 6.4 transmission leaking out of the top of dipstick tube.
Ok new guy to the site I've read and searched the forum a ton and learned a lot. I wanted to ask some of you ford guys that know a lot more than me. This is my first SD truck and I love it. Question is my transmission is blowing fluid out of the dipstick tube and also from the top of it I suspect it's the vent but what causes this other than over fill which it has never been over full. The truck just started doing this on my last trip pulling the travel trailer. It was all back roads and not over 55 with TH on. Got to the house and there was fluid dripping. Anyways anyone know what could cause this thanks guys for the help ... also the truck has 206k on it
I have no idea really, but I have read here about transmission fluid puking out of the front pump seal and I think the reason is that it's overfilled but nothing happens riding around empty. But when they start towing it heats up and being overfilled it starts puking.
have you checked the fluid level?
That's what I thought first but I've been monitoring it with my H&S mini maxx and in 98 degrees stop and go traffic it was reading 205 to 208. I am still wondering if something is blocked just need to start the process of trying to find it i guess
[QUOTE=Mark Kovalsky;18208172]yes sir I check it after letting the engine warm up for a while usually engine temps around 180 or so.
No, that's not right. Engine temperature has no bearing on transmission fluid level. You need to drive it at least 10 miles before checking the trans fluid level.
True Mark but what I'm saying is I've checked it after driving 100 miles 10 miles and even in between 30 hour trips to Wyoming and it's always been perfect. I haven't touched the fluid since I've owned the truck and have pulled trailers since I've owned it which is about 2 years. If it was over full wouldn't it have puked fluid out before. I guess I'm just wondering if I have something wrong with the trans ... checked it after driving today trans was 184 from about a 30 mile round trip it's low and still leaking out the top
You're going to need to find out exactly where it's coming from. Mirrors may help. The only times I've seen fluid come out of a dipstick is when the trans was overfilled, or water got inside the transmission. A little bit of water can flash to steam and GREATLY expand, forcing fluid out of the dipstick.
You're saying that now, that isn't what you said before.
It could have blown fluid out because it was hotter this time.
If the trans is in good shape new fluid can only help it. If the trans is about to die new fluid won't prevent it. Many places won't change fluid on an older trans because many people never service their transmission. Then something starts to go wrong, and they have the fluid changed. Net the trans fails. It failed because it was ignored for 200,00+ miles, not because it had the fluid changed. It would have died without the fluid change too.
kneeman
1999 to 2016 Super Duty
04-12-2011 11:21 AM
