Dipstick read question.......
Old Mar 29, 2018 | 08:36 PM
Scuds ion's Avatar
Scuds ion
My 2005 Excursion with the 4R100 transmission........
It's strange to me.......
Why does my dipstick only seem to register fluid on one side......?
It is as if the dipstick is somehow horizontal......can't get a trusted reading.,
I am crazy?
Thank you.
Old Mar 30, 2018 | 11:20 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
One side has "hatching" cut into it to catch the fluid in the squares. The other side is smooth, so that smooth side does not reliably read fluid level. Only read from the "cut hatching" side.
Also to consider: The dipstick goes in at an angle through the tube, so it picks up fluid from the tube if you just filled/added fluid. This gives you a false reading unless you wait a while before checking the fluid.
Old Mar 30, 2018 | 12:50 PM
projectSHO89's Avatar
projectSHO89
Also, insert it so the cross-hatched area is on top as it goes in and comes out. Otherwise, the cross-hatched area will smear against the side of the tube and cause inaccurate readings.
emmagator
Oct 29, 2013 06:23 AM
kneeman
Apr 12, 2011 11:21 AM
cmoffatt23
Mar 8, 2008 06:53 PM
SShank42
Escape & Escape Hybrid
Jul 8, 2007 10:35 AM
mickf66
Oil & Lubrication
Aug 16, 2004 11:20 AM
