Which HPOP to replace
Old Sep 19, 2018 | 11:45 AM
riverstroker04's Avatar
riverstroker04
Have an 04 350 from what I have figuard out is that the HPOP ball bearing has gone out, hard start first thing in the morning and oil pressure gauge drops to zero at idle but jumps back up when I push the skinny pedal. Question Is I'm running 155cc injectors so do I go back with stock hpop or the adrenaline hpop?
Old Sep 19, 2018 | 12:15 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
You can go back with stock and be fine from an output perspective (FORD OEM 6.0L V8 High Pressure Oil Pump (HPOP) for 2003-2004.5 models) but the stock pump has plastic parts in it that love to fail as well vs the Adrenaline pump with 12 improvements over the stock parts (2003-2004.5 HEAVY DUTY HIGH VOLUME FORD 6.0L / IH VT365 BILLET HIGH PRESSURE OIL PUMP (HPOP)).
Hope this helps!
Old Sep 21, 2018 | 10:20 AM
DarkStarMedia's Avatar
DarkStarMedia
If you are talking about the dash guage then it's low pressure oil pump that might be the issue. Your hpop may be fine. Is it an early or late 04 (ie is the icp on the pass valve cover)?
Richard
Old Sep 22, 2018 | 11:26 AM
riverstroker04
Richard
Morning, its the late 04. From what I've read there is a ball bearing that pops out of this stile hpop that let's the oil drain out of the top end of the engine. If it was the lpop issue then it wouldn't give the hpop enough oil to fire the injectors.
Old Sep 22, 2018 | 12:14 PM
DarkStarMedia
If it's a late 04 with the ICP sensor on the passenger valve cover, it's not likely your HPOP. The later one almost never fail.
I would get an oil pressure gauge and check your base oil pressure. You can also pull the oil filter and hold down the drain valve while cranking to see how fast it fills.
Richard
EDT: after they went to the later pump it didn't really change till the end of production. it could also be a leaking STC fitting too. Unless I am getting my dates wrong I have only really dealt with the later motors.
Old Sep 22, 2018 | 01:01 PM
navistarnut's Avatar
navistarnut
Late 04 still has the early pump with the STC tube style that rarely fails(the fitting that is)
Time for an air test
Old Sep 22, 2018 | 04:37 PM
riverstroker04
you sir are correct! There is also a ball bearing inside the hpop that fails on these ones I'm guessing that's what it is from what I have tested well find out in a day or two when I take it apart.
Old Sep 22, 2018 | 10:39 PM
navistarnut
It's still possible you have an oil rail leaking down, with a hard cold start. Pull the ICP after it's been sitting overnight, if the oil is not right there at the top of the hole it might be the culprit.
This only works for the passenger side obviously. It could be the drivers side as well if this is the issue and would require pulling the valve cover and dummy plug.
Would hate to see you go through all the work of pulling all that stuff topside if not needed.
Old Sep 22, 2018 | 11:34 PM
riverstroker04
ok I'll check that in the morning, I have the air test fitting coming so I'll air it up before I take it all the way down. I did replace those about 30k miles ago when I did studs and EGR upgrade.
Old Sep 23, 2018 | 06:17 AM
bismic's Avatar
bismic
What testing did you do that pointed you in the direction of that pressed in ball?
Old Sep 23, 2018 | 07:56 PM
riverstroker04
ICP off oil still in oil rail, ipr at 85% when cranking icp desired pressure 1100, icp actual pressure 100+ then jumps up to the 1100+ truck fires and then dies next crank ipr 22% and icp 700+ truck fires and runs sits for an hour long crank repeat of above
Old Sep 23, 2018 | 09:01 PM
bismic's Avatar
bismic
Here is a recent thread where a person found the ball had come out. He describes his symptoms. Edit - after re-reading your first post in this thread, it seems more in line w/ the link below than what I got from your post above.
https://www.thedieselstop.com/forums...04/index2.html
Old Sep 23, 2018 | 09:16 PM
TooManyToys.'s Avatar
TooManyToys.
I’ve never thought much about that part, or more to the point, the ball bearing. I remember reading one company had a pipe plug in that location. Mark, do you have any knowledge of what that part does and why it blows out? I had thought at some point that is was an over pressure plug, designed to pop. But that can’t be true if there is a pipe plug there.
Old Sep 23, 2018 | 09:26 PM
riverstroker04
thanks I have read a few different post on this form and some others that all say around the same thing although this one has more info than the others. I am waiting on the air test plug and a few seals that all should be here around Wednesday so I'll dig into her around the end if the week and update you all on what I find.
Old Sep 24, 2018 | 07:13 AM
bismic's Avatar
bismic
I read it somewhere, just can't recall. I'll have to look around and see if I can find it again. I think it was in a Tech Time video that I no longer have access to.
It was put out in 08 and was where I first saw the discussions on cracked heads (fuel in coolant).
fordstar/66920.wmv
It was a great video on HPO components/issues/diagnostics. I've sometimes wondered if a Tech would be able to access this old training video.
