Need a cheap tailpipe
Old Sep 19, 2018 | 08:55 AM
RCB1125's Avatar
RCB1125
This is a 2000 7.3. So my exhaust is broke above the rear axle. None of the shops seem to able to repair it for less than 150. In the spring I want to but a full stainless exhaust but in the meantime would a cheap tailpipe like this work? https://www.summitracing.com/parts/w...2/applications It's for the truck but I'd think it'd work for an excursion as well.
Old Sep 19, 2018 | 09:24 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Your local shops are likely using a walker part to fix yours, I wouldn’t call them “cheap” as a walker aluminized steel exhaust will last as long as any of the name brand stainless systems ..... possibly longer because the steel isn’t brittle and doesn’t crack as easy as the stainless.
Will that part ypu linked work ? Maybe, The Ex has the tank in the rear and I recall that section being diffrent then the trucks.
Old Sep 19, 2018 | 08:49 PM
agsmv1's Avatar
agsmv1
It might work, but don't forget the 4" adapter as well., I forget what size the stock exhaust is 3' or 3.5"..plus clamps if you aren't welding it in.
Old Sep 20, 2018 | 08:00 AM
RCB1125's Avatar
RCB1125
Good point. I'm thinking of running 4" up further if I can find some 4" straight pipe locally.
Old Sep 20, 2018 | 02:09 PM
Squirrel13's Avatar
Squirrel13
Where are you located. I just cut my stock exhaust off at the muffler and the pipe is in my garage in Aurora, CO
TXSD6.2
Jun 17, 2018 07:50 AM
taylintaysin
Modular V10 (6.8l)
Jul 29, 2011 05:07 PM
wildstang
Nov 25, 2009 02:11 PM
boxcar1974
Exhaust Systems
Sep 20, 2006 07:09 PM
oldfordtrucksrule
Exhaust Systems
Apr 4, 2004 10:31 PM
