Some tech questions
Old Sep 18, 2018 | 07:33 PM
tkmitchell's Avatar
tkmitchell
Some tech questions
Where is the blower motor resistor located? Fan has stopped working and there is power to the plug that goes into the motor. So either motor or resistor.
What amount of vacuum does the vacuum assist on the brakes need to work properly. Brakes seem soft. Have bled them and checked. I have vacuum coming from the Cummins vacuum pump. I believe it should be pulling 20"hg when working correctly. I will be testing it tomorrow.
Old Sep 18, 2018 | 07:48 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Blower motor is right next to the blower motor
if nobody knows the correct vacuum here in a bit I’ll go look it up on the manual when I get home
Old Sep 20, 2018 | 03:14 PM
PrescottIce's Avatar
PrescottIce
The TECH FOLDER has most everything one could want to know:
https://www.ford-trucks.com/forums/1...l#post13549509
Good luck, hope it's simple.
MMG
Jun 19, 2013 05:38 PM
bigb609
Nov 29, 2011 09:20 AM
stangbanger
Feb 24, 2009 09:07 AM
SuperDutyDave
Aug 17, 2004 10:28 AM
1993F150XL
Jun 5, 2003 08:47 AM
