Electrical problem
Old Sep 17, 2018 | 09:35 PM
Megathomas's Avatar
Megathomas
Exclamation Electrical problem
I've got an electrical problem, the brake lights don't work when the pedal is pushed. The blinkers don't work unless you turn the hazard on, they don't flash but turns the brake light on the left side running lights on the right, I also unplugged the brake light switch and the blinkers work normal. Is this the multi-function-switch?
Old Sep 18, 2018 | 10:05 AM
alloro's Avatar
alloro
I'd say the MFS or the flasher relay.
Old Sep 18, 2018 | 10:33 AM
Megathomas's Avatar
Megathomas
the flasher works so does the MFS
Old Sep 18, 2018 | 07:38 PM
Franklin2's Avatar
Franklin2
From your description, a good guess would be the multi-function switch is faulty. How do you know it's good?
Megathomas
Sep 16, 2018 12:34 PM
columbia1spring
Apr 20, 2018 12:44 PM
breadstick
13
Mar 19, 2012 08:32 PM
Timon5435
Dec 18, 2008 06:18 PM
Galizien
Oct 3, 2006 03:29 PM
