Sponsored by: Real Truck
Transmission issues
Old Sep 17, 2018 | 05:26 PM
Eugene D's Avatar
Eugene D
Transmission issues
I canged the filter and fluid in my transmission now its jerky in reverse and slams from 3rd to 4th won't go into od then the green wrench comes on and it will shift fine 1st thru 4th still no od and still jerky in reverse. Any advice would be greatly appreciated. Thank you in advance
Old Sep 17, 2018 | 05:31 PM
02TB250's Avatar
02TB250
what year truck and what motor? Did you use factory filter what type of fluid did you use? Did you check the fluid with the truck running in park?
Old Sep 17, 2018 | 06:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Either the fluid level is wrong or the internal filter isn't right, or isn't installed right.
Old Sep 17, 2018 | 06:56 PM
Eugene D's Avatar
Eugene D
is there different filters it looked just like the one I pulled out and I put 8 quarts in
Old Sep 17, 2018 | 06:57 PM
Eugene D's Avatar
Eugene D
it is a 2008 6.4
Old Sep 17, 2018 | 08:54 PM
Mark Kovalsky
There are two different filters. One was used from 2003 until mid year 2008. The second was from mid year 2008 until the end of production The wrong filter will cause big problems.
Another thought - what fluid did you use?
Old Sep 17, 2018 | 08:59 PM
Eugene D's Avatar
Eugene D
motor craft sp that's what it called for
Old Sep 17, 2018 | 09:10 PM
Eugene D's Avatar
Eugene D
also do the filters look the same
Old Sep 18, 2018 | 12:16 AM
j1586's Avatar
j1586
I would check you fluid level again. On level ground, transmission in normal operating range for temp, and cycle through all gears. The 5r110 has a 17.5 qt capacity, with roughly 8 qt in the pan. If you put 8 back in that doesn't mean it was the right level before. Did you change the cartridge filter next to the radiator?
Old Sep 18, 2018 | 12:41 PM
Eugene D's Avatar
Eugene D
It doesn't have the filter by the radiator I don't know if that makes a difference or not but mine is the 5R110w Torque shift
Old Sep 18, 2018 | 09:51 PM
Mark Kovalsky
No, they don't. The later filter is quite a bit larger.
All of them are the 5R110W TorqShift.
Since you don't have the filter near the radiator you should have the larger, later filter. If you install the earlier filter it's going to cause problems.
Old Sep 20, 2018 | 04:45 PM
Eugene D's Avatar
Eugene D
ok the larger one doesn't fit we hook it to a computer and it shows shift solenoid d I replaced it and it's still doing the same thing any thoughts
ronwarepctech
Nov 19, 2016 11:31 PM
67Ray
Escape & Escape Hybrid
Feb 25, 2011 11:20 AM
DaveWW00
Mar 28, 2005 03:17 PM
atutt
Aug 31, 2004 10:40 PM
jgrm2
1997 - 2003 F150
Jul 22, 2004 08:52 PM
