Turn signal switch not fitting?
Old Sep 17, 2018 | 10:25 AM
goodm3's Avatar
goodm3
I just installed a replacement switch from Dennis Carpenter. This video was a bit helpful:
. Everything lined up correctly, the metal post on the lever side is inserted in the hold on the column, and the small hole in the plastic fit over the pin. The problem is the lever hits the column and can't push it down enough to make the left turn signal light up. Am I missing something, or it just a poor fitting part? I really don't look forward to having to take it out again. See attached pic, when turn signal is OFF, it is almost hitting the bottom. Last resort I could grind a bit of the opening.
Old Sep 17, 2018 | 10:55 PM
1browski's Avatar
1browski
I am no help but this is my next project. Going to check out this video too. I have this video saved to my desk top as well.
Old Sep 18, 2018 | 09:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D0TZ-13341-B .. T/S Switch / Obsolete/Reproduced ~ Genuine Ford available NOS
1969 F100/350 from serial number G30,001; 1970/72 F100/350.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has 3 = 763-434-0123.
MILLER OBSOLETE PARTS in Binghamton NY has 3 = 607-722-5371.
RPN PARTS in Erie PA has 8 = 888-864-9305.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1,302 = 800-476-9653. You have to ask for genuine Ford, otherwise you get made in China repro's.
Old Sep 18, 2018 | 11:29 AM
Old Coyote's Avatar
Old Coyote
I don't think there's really much that can go wrong with installation that would cause this problem. The switch only fits one way with the small screws that attach it to the column flange. The piece that the lever screws into only fits one way in the switch. Only thing I can think is the threaded hole the lever screws into is misaligned?
Old Sep 18, 2018 | 01:06 PM
RichS2659's Avatar
RichS2659
The big question is: What column is that, anyways? As 67-72 4wd's never had automatics, what column was used, and how was it connected to the steering box? Does it have a hazard light switch on the column, which would signify a Dent column.
Old Sep 24, 2018 | 07:17 PM
JEFFFAFA's Avatar
JEFFFAFA
Good eye Rich. With that groove in the flange ahead of the shift pointer I'd guess the 73/77 pointer and PRNDL bezel fits there. So I think it is a 73/77 column. Which takes a different switch.
OP, look at the wiring on your old T/S switch for an engineering number sticker. Post what numbers are on that tag. Example would be D3TE13B302AB.
Old Sep 24, 2018 | 07:30 PM
goodm3's Avatar
goodm3
Thanks for letting me know that! I wasn't aware that there were no auto 4x4's in 1971. Another issue I'm having is there is a 1/2" gap between the column and the steering wheel. Maybe that is why? I have a power steering swapped box in it. I put a Red Head 2754. I dropped the truck at a steering column re-builder shop since the bottom bearing is blown apart.
shty150
Mar 16, 2016 05:54 PM
eminencefront
Oct 1, 2014 10:28 AM
thunderbirdcakes
Sep 24, 2012 12:26 PM
grm61
19
Jan 31, 2009 10:00 PM
Luddle
Jan 4, 2009 08:30 PM
