Hi guys. Working on my turn signal switch. They don't self cancel. Removed wheel and cleaned everything up and found these sitting in the bottom of the column, under the turn signal switch assemble. Anyone know what they are/where they go? Don't want to buy parts if I don't need them. Any help would be appreciated. Thanks!
The switch is the electrical portion and may not be needed.
Check Gary's site : Gary's Garagemahal - Home
for illustrations and serviceable parts.
Hippo Parts also sells the parts catalog disc.
Hope this helps...
You are very welcome...Just a hint, go into user cp and enter your vehicle specs as well as the area that you hail from. It may not seem important now but, it can be very relevant in the future with other inquiries.
