38 Gallon Fuel tank float modification
Old Sep 16, 2018 | 04:23 PM
highoctane74's Avatar
highoctane74
Has anyone come up with a fool proof way to extend the float on the sender?
I thought I was smart and used a piece of coat hanger to make a new arm but it doesn't work well, it's too heavy.
Has anyone used a newer bigger float from another vehicle?
What metal works good for making an arm?
Old Sep 16, 2018 | 05:06 PM
mark a.'s Avatar
mark a.
I used 70-18 welding rod. You can get it in most any size and it holds any shape you put in it..
Old Sep 16, 2018 | 06:04 PM
84espy's Avatar
84espy
I carefully bent the stock arm down. It shows empty when there is about 7 gallons left. This is something I can live with.
Old Sep 16, 2018 | 06:18 PM
FORD~'s Avatar
FORD~
I used this sender which easily accommodated the 38 gal tank. I found the sender wasn’t perfectly accurate though. https://www.cjponyparts.com/efi-fuel...tanks/p/FSU45/
Gary E
Nov 14, 2013 03:17 AM
DGMFORD
Apr 30, 2013 10:44 PM
dbellis
Apr 9, 2007 12:21 PM
uk1050
Feb 17, 2006 12:21 PM
qman
Sep 28, 2004 08:13 AM
