Sponsored by: Real Truck
Climate control
Old Sep 16, 2018 | 09:51 AM
Kevman37664's Avatar
Kevman37664
Climate control
All of a sudden my 1999 f350 will not engage the ac compressor or let me change the temp inside of the tuck to even have the heat work. All of the different feet, face and defrost selections work like normal. Any ideas would be greatly appreciated. All of this worked the day before it happen.
Old Sep 16, 2018 | 01:29 PM
ligito's Avatar
ligito
Have you checked the spacers in the front of the compressor? They can be adjusted with a feeler gauge.
Old Sep 16, 2018 | 01:40 PM
projectSHO89's Avatar
projectSHO89
1999 f350
Gas or diesel engine?
That will only cause the compressor clutch to not engage. See where he said " will not ... let me change the temp inside of the tuck to even have the heat work. "? That means you need to focus on something that is common to both the clutch operation and the operation of the temperature blend door. Start by checking fuse F24 under the dash.
Old Sep 16, 2018 | 01:41 PM
Kevman37664
I can apply power to the compressor with a set of wires and it works and blows cold air, so i know that everything is working ok with it. Its that the climate control doesn't turn it on itself, it also will not let you change the temp of the air
Old Sep 16, 2018 | 01:42 PM
Kevman37664
Its the 7.3 diesel
Old Sep 16, 2018 | 03:29 PM
projectSHO89
Read previous reply in its entirety...
taxgod4u
Jul 14, 2018 08:55 AM
neilc88
Oct 6, 2015 03:31 PM
BigRed7.3l
Jun 7, 2014 12:37 PM
knuckleheadnut
Oct 26, 2010 12:09 PM
txzaphod
Aerostar
Nov 10, 2003 08:06 AM
