let me get this straight... the a/c compressor is engaged and pumping fluid even when (for example) the mode selection is defrost and the temp control setting is set to high heat. (as long as the ambient outside air temp is greater than 43*F, IAW owners man).
What a primitive design then. I thought A/C technology had advanced further than that by '02. But I must be wrong. thanks-
It runs to help control humidity. I remember the days when you turned the vent to blow on the windshield in the winter, but also turned on the AC so the heat didn't fog up the window.
most AC systems run that way, the AC is used to control the humidity...I had to run around for a year w/o ac in my truck and it was almost impossible to keep the windows clear with 2 adults and 3 kids in the cab.
I assume you mean OFF only in panel, off and feet mode! otherwise, compressor is "ON"?????? As opposed to "except in".
How did I ever get by all those decades without A/C to help me clear my windows. Life was tough back then.
No wonder they quit working so soon, they run all the time whether you need 'em or not. I'll have to remember to leave it in "panel" mode to get nice cool dry un-A/C air, like today. Not bitchin', just adapting. Hard for old goats {];-/>
thanks for the replies!
Reason: typos
When it starts to get cool in the fall, I unplug mine at the compressor. On most vehicles in the past, I have put a switch under the dash to turn it off.
Mark- pulling the switch at the compressor sounds like a great idea. I just can't see running the comp when it's not needed. That way I'll save it for when I retire down south (some day, I hope) and it'll be running all the time.
