fuel filter drain
Old Sep 15, 2018 | 05:22 PM
ae6940t's Avatar
ae6940t
fuel filter drain
I have a 2017 ford f250, went to change the fuel filters upper changed no problem. the lower one which is a water separator, keep draining fuel, never stopped. I have about 2 gallons of diesel fuel. Videos don't show this problem
Old Sep 15, 2018 | 06:23 PM
elee3's Avatar
elee3
You need to unscrew it 3 full turns before draining.
Old Sep 15, 2018 | 08:48 PM
HRTKD's Avatar
HRTKD
There's another thread from within the past week that discusses this same problem. A couple work arounds are in that thread.
Old Sep 16, 2018 | 09:49 AM
First3Quarter's Avatar
First3Quarter
Unscrew what?
Old Sep 16, 2018 | 10:04 AM
HRTKD's Avatar
HRTKD
Originally Posted by First3Quarter
Unscrew what?
Scratching my head on that one also. Maybe that refers to something prior to 2017?
Old Sep 16, 2018 | 01:11 PM
SkiSmuggs's Avatar
SkiSmuggs
That would be 3 turns on the main fuel filter housing cap to engage a check valve. Then open the drain, close when it stops draining, remove the housing cap and replace the filter.
Old Sep 16, 2018 | 01:30 PM
FishOnOne's Avatar
FishOnOne
The OP has a 2017 truck with the new rectangular shaped fuel filter so there's no round fuel filter housing anymore to unscrew to activate the fuel shut off valve.
Old Sep 16, 2018 | 01:49 PM
schlepprock250's Avatar
schlepprock250
So with a pre '17 we unscrew the housing three turns before opening the drain valve? Hmm.. Didn't know that.
Old Sep 16, 2018 | 07:23 PM
kper05's Avatar
kper05
Pre 2017, correct otherwise the DFCM will siphon the tank.
I have no idea on a 2017+. I haven't seen one of the square filters in person yet.
Old Sep 16, 2018 | 08:10 PM
schlepprock250
I've had my '14 Lariat for a little more than a month now. I changed all the filters when I got it home. I was wondering if it was normal for the fuel to drain for as long as it did. Thanks guys for the info.
Old Sep 22, 2018 | 03:21 PM
KR2012F250's Avatar
KR2012F250
Unsrewing the filter housing 3 turns allows to break the vacuum and consequential fuel draw from tank, generated during drain.
klassic
Mar 29, 2019 07:59 AM
Spode
Sep 11, 2018 11:40 PM
aaronabp
6.7L Power Stroke Diesel
Dec 20, 2016 09:10 PM
jbrouse
6.4L Power Stroke Diesel
Oct 14, 2012 02:39 PM
Larry NCKS
May 21, 2011 09:01 PM
