Heat riser on exhaust question
Old Sep 14, 2018 | 10:03 AM
rsh1966's Avatar
rsh1966
Ref: 1966 f100
I know that the heat riser Is on the exhaust to get the engine warmed up faster but my question is.....If the heat riser is not functioning will the motor rung ok after running for a while or will the motor not run smoothly. So, is the heat riser really necessary?
I would post a pic but I don't have one right now.
thanks
rsh1966
Old Sep 14, 2018 | 10:19 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Originally Posted by rsh1966
Ref: 1966 f100
thanks
rsh1966
No, not really necessary - once the heat riser opens fully then it is (almost) like it's not there. It is not needed once the engine is warmed up and lots of people run without them. If the heat riser is rusted/frozen open it doesn't cause any harm but if it is rusted shut or the spring is broken then it can at least partially block the exhaust on that side so sometimes they can do more harm than good, too.
Chad
Old Sep 14, 2018 | 12:41 PM
rsh1966's Avatar
rsh1966
Thanks Chad, that is what I though but it is always good to hear other opinions.
thanks
Richard
Old Sep 14, 2018 | 03:20 PM
Tedster9's Avatar
Tedster9
Many people would wire them open or remove the flapper entirely. Don't want it rusted/stuck in the closed position.
Old Sep 14, 2018 | 08:10 PM
78ShortBed-'s Avatar
78ShortBed-
I usually always cut the flapper out, back in the day.
Old Sep 15, 2018 | 10:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
fabieber
17
Nov 16, 2015 02:20 AM
65F100390
Oct 27, 2010 05:46 PM
66fordf100
Nov 26, 2007 05:45 PM
