2018 Diesel fuel issues
Old Sep 12, 2018 | 07:41 AM
Ted62's Avatar
Ted62
Trailering
Hey guys several topics here-hope someone can help: (2018 350 4x4 diesel)
1) My DTE is at 10 miles -to fill my 34 gallon tank it takes 27 gallons- per design by Ford (unbelievable!)
Is the best fix- set tank to 40 gallons with Forscan? Does it do damage to fuel pump to run reserve down to 2-3 gallons?
What are the issues if this engine runs out of fuel? restart procedure?
2) I have added a 60 gallon gravity feed aux tank (works great w/up fitter switch)
I want to use aux tank for hauling gasoline for boat in Mexico. Quote from my Ford diesel service rep.. "two teaspoons of gas mixed with 60 gallons of diesel will damage my 6.7! True?
Old Sep 12, 2018 | 08:39 AM
Blwnsmoke's Avatar
Blwnsmoke
Restart procedures are in your manual.
You do NOT want to run put of fuel as the pump is cooled by the diesel and they are ultra sensitive.
You also do not want to get any gas in the motor for reasons above. These are not your 90s diesels where they will run on anything. These are super high pressure fuel systems.
Old Sep 12, 2018 | 09:11 AM
N2dunz's Avatar
N2dunz
Gas mixed with a modern diesel????
No way. That is crazy.
These things are so ultra sensitive.
Old Sep 12, 2018 | 09:37 AM
BillyE's Avatar
BillyE
Unlikely. I've seen studies of blended gas and diesel. It increases wear but not at those levels. Still, it's not a great idea. I still wouldn't do it...
Old Sep 12, 2018 | 10:35 AM
bitNine's Avatar
bitNine
Ford does seem to go a bit overboard in the DTE department. My Ram was "empty" at 3 gallons left. That' would typically give 30 miles while towing, and I never had a problem with that. However, when I last got my SD to zero, I put 29 gallons in it.
Old Sep 12, 2018 | 10:45 AM
cficare's Avatar
cficare
Mine is a 2017 Job 2 and does the same thing, but it doesn't bother me any. There was a TSB for early 2017 SDs about DTE readings versus fill-up amount, and the problem seems to persist.
Here are a couple threads on the TSB ...
https://www.ford-trucks.com/forums/1...-tank-tsb.html
Old Sep 12, 2018 | 01:04 PM
hi3cho's Avatar
hi3cho
My DTE was pretty dead on, only my first tank so not sure if it will continue. I filled up with ~100 mi to E, it took ~42 gallons of my 48 gallon tank. With my average of 16MPG it was pretty dead on.
Old Sep 12, 2018 | 02:49 PM
cficare's Avatar
cficare
Along that line, my lie-o-meter was off. Calculated MPG was consistently only 93% of what the meter was displaying. Thanks to FTE, the following post detailed how to adjust the rate at which your truck calculates MPG. My meter is now in agreement with my hand calculations. Plus, you do not need FORScan to make this change.
https://www.ford-trucks.com/forums/1...l#post18097223
GEugeneS
Feb 14, 2013 10:22 PM
dieselcontam
General Diesel Discussion
17
Jun 9, 2011 01:41 AM
Kookadala
May 22, 2009 12:48 PM
94 Turbo
17
Feb 7, 2009 10:56 AM
bz919
May 6, 2004 03:59 PM
