Power window problems
Old Sep 9, 2018 | 10:34 PM
'94's Avatar
'94
I have had my 2004 6.0 X for a year now. The rear passenger window has never worked for me. I finally had time to try to find out what's going on and I think I have a bad wire.
closest I've come to it working is I got the light on the rear passenger switch to come on at the RP door, and got the motor to go up... Only up. No idea how I got that to happen, and it stopped soon after. no amount of wire jiggling has brought it back. I started looking at the wires in the driver door jam and i have no idea what goes to what. Does anyone have a color key that says what wire goes to what?
Old Sep 10, 2018 | 11:17 AM
mecdac's Avatar
mecdac
https://www.ford-trucks.com/forums/1...excursion.html
Wiring diagrams
Old Sep 11, 2018 | 12:11 PM
Markken's Avatar
Markken
For a quick testing method, you can do this with the key off, grab a 9 volt battery and you can jumper right to the pins to check motor/switch issues. The 9 volt battery is strong enough to run the window motor.
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
Az_Green_Machine
Apr 24, 2015 10:29 AM
78_79ford
Nov 16, 2014 12:13 PM
akfalconer
Electrical Systems/Wiring
Jan 18, 2006 07:22 PM
loquito
1978 - 1996 Big Bronco
15
Mar 1, 2004 08:53 AM
