Sponsored by: Real Truck
4x4 switch
Old Sep 9, 2018 | 08:36 PM
Vinford's Avatar
Vinford
4x4 switch
where to start troubleshooting 2001 f350 diesel.
Wont go in 4x4 wheres a good place to start troubleshooting?
Electronic shift button?
4x4 light doesnt come on and 4x4 doesnt engage. Fuses good.
Old Sep 10, 2018 | 09:59 AM
seville009's Avatar
seville009
Crawl under the truck and look at the transfer case motor wires to make sure they’re plugged in and not broken.
Old Sep 10, 2018 | 10:59 AM
alloro's Avatar
alloro
There are contacts down in the transfer case motor that control the dash lights. Since it's not shifting and the dash lights aren't working, you have a frozen shift motor or a blown fuse for it's circuit.
Old Sep 10, 2018 | 12:15 PM
Vinford's Avatar
Vinford
Shift motor is in the transfer case?
2 sets of wires going to transfer case , 1 set has 2 wires and other has multiple wires?
Old Sep 11, 2018 | 10:36 AM
alloro's Avatar
alloro
Not in it, it's mounted to the back of it next to the driveshaft with 3 bolts. For your model it's called the gearmotor encoder assembly not a shift motor.
Old Sep 11, 2018 | 11:11 AM
00t444e's Avatar
00t444e
On an 01 the shift motor is mounted on the side of the transfer case.
Old Sep 11, 2018 | 11:50 AM
speakerfritz's Avatar
speakerfritz
check for cracks on the dial **** shaft...if its cracked..dial will just spin with out moving shaft. if cracked, replace dial **** or super glue the crack.
Daniel Buchanan
Aug 31, 2017 08:42 AM
doorider
Feb 20, 2011 05:07 PM
distortedcloud
Mar 25, 2009 03:04 PM
boatcop1
Jul 28, 2005 05:49 PM
