Transfer case issue *video*
Old Mar 24, 2009 | 08:08 PM
distortedcloud's Avatar
distortedcloud
Hey guys,
I've been having a problem with the transfer case lately. It shows that it is in 4Lo, when the switch is not. I'm not sure if the electrical plug got water in it from all the snow(put some dielectric grease in it yesterday and didn't make a difference, and removed the front driveshaft too).
I put up a short video clip on youtube for everyone that sees it will understand what is going on.
YouTube - 4wd not working properly
Any help will be appreciated, I will be working on this through out the evening to hopefully resolve this issue, as I have a 12 hour drive in front of me come friday.
Thanks.
Old Mar 24, 2009 | 08:21 PM
rusty350250's Avatar
rusty350250
looks like to me that the t-case is in 4 lo, did u turn the switch rece ntly to lo for it to shift then not shift back? how long has it been doing it? when u drive does it feel like it is in lo range or just 4x4? the shift motor conector might be dirty and not wanting to shift it. the connector on top of the case(range sensor(make the light go on) sounds like it is working.
Old Mar 24, 2009 | 08:34 PM
distortedcloud
I'm in the process of removing the shift motor and and clean other connections.
Its only been like this for a couple of days, it never happened last winter, so who knows.
Every once in a while, while driving it'll try to engage(hence why the front driveshaft is off), but the lights so on constantly.
Anyways, better keep on working on a solution.
Old Mar 24, 2009 | 08:57 PM
rusty350250
sounds like the case is just stuck in gear. i had the same problem and it was a corroded wire under the 4x4 relays in the engine compartment. when the motor is removed turn the stub that the the motor turns to the 4x2 spot and check the light, if it goes out try switching the motor with the switch while it is removed fomr the case. you might just have a bad wire somewere. for your trip you can manually shift the case to 4x4 then move the motor to 4x4 and reinstall and deal with it when you get back.
Old Mar 24, 2009 | 09:36 PM
xccxsinnerx's Avatar
xccxsinnerx
i dont know if its the same but my dad had the same problem with his chevy turned out his dog chewed on the wires for the 4x4
Old Mar 25, 2009 | 10:44 AM
guthrie&co's Avatar
guthrie&co
Ever seen a dog chew on a turd? Same thing
Old Mar 25, 2009 | 10:57 AM
Bergerson's Avatar
Bergerson
^^^^^^what he said^^^^^^^
Old Mar 25, 2009 | 02:08 PM
DieselCamper01's Avatar
DieselCamper01
While not helpful funny none the less! haha
Old Mar 25, 2009 | 03:04 PM
Kwikkordead's Avatar
Kwikkordead
Here's my ordeal complete with pictures if you need to see what's inside.
https://www.ford-trucks.com/forums/3...ce-needed.html
