Tailgate weight tolerance when it's down?
Old Sep 9, 2018 | 09:26 PM
HRTKD's Avatar
HRTKD
If the OP hasn't thought to consider that question, he should. There was a similar discussion a few months back and what I got out of it was that it would be prudent to not have the wheels of the ATV resting on the tailgate while driving the truck. I think that assumed that it was one of the larger ATV's not a dinky one.
The number of aftermarket solutions that came up in that thread were pretty interesting.
Old Sep 9, 2018 | 09:46 PM
00t444e's Avatar
00t444e
A truck wouldn't be worth having if you couldn't load a 4 wheeler in the bed with ramps.
Old Sep 10, 2018 | 09:13 AM
BigTexDiesal's Avatar
BigTexDiesal
I load my foreman all the time zero issues with tailgate. the weak link is the cables. A company on ebay actually sells a plate that can be installed with tailgate down to support vs cable. Nice thing is it keeps the tailgate from bouncing also if not loaded. I used 9' ramps. The challenge is finding ramps narrow enough to fit between the atv wheels. I founds some on ebay 1500 lb rating. 12" wide x9' long aluminum about 20lbs a ramp. Be warned heavy ramps are akward and you may ding your truck accidentally. you want the lightest that will do the job. I had some ramps weighted 50lbs each WAY to heavy, sold on craigslist and took forever to sale.....
Old Sep 10, 2018 | 09:21 AM
N2dunz's Avatar
N2dunz
I bent the sheetmetal on the tailgate on my 06 F350 loading a Rhino into the bed.
After that, I built a support for the entire width of the tailgate.
Took a 2X12 and cut out notches to where it would span the width of the tailgate yet fit around the pillars where the tailgate latched.
The rear wheels of the Rhino then rode on this wood and I didn't have any more issues after that.
Old Sep 11, 2018 | 01:00 AM
Sheepdogg's Avatar
Sheepdogg
This happened on my'08 Tundra also from my Honda Foreman 4 wheeler. I had a tool box in the bed, so the rear wheels rested on the tailgate while driving. I guess I hit some pretty good bumps causing the right rear tire to actually dent the tailgate sheet metal. I will not travel with a 4 wheeler resting on the tailgate without a piece of plywood or something to spread the load.
Old Sep 11, 2018 | 09:12 AM
Horsehaulin8's Avatar
Horsehaulin8
When the 4 wheeler is loaded, it's not on the tailgate, i'm able to close it with no problem. My concern was the actual loading, was it too heavy to damage the tailgate. Even though it's quick.
Old Sep 11, 2018 | 01:19 PM
Sheepdogg's Avatar
Sheepdogg
In that case, you should be good. JMO My comment was to help others avoide the same mistake I made.
Old Sep 11, 2018 | 04:36 PM
seville009's Avatar
seville009
Can always remove the tailgate to load something if there is a concern about it, then just stick it back on once the item is loaded.
To prevent the loaded item from slamming against the tailgate while driving, make sure it’s secured to the front so it can’t roll back.
Old Sep 11, 2018 | 07:36 PM
danr1707's Avatar
danr1707
This works well
marksman76
General Automotive Discussion
Nov 20, 2018 01:35 AM
Jlepper
Mar 2, 2018 04:05 PM
Brian Singstock
Sep 7, 2017 09:02 AM
barry1me
2009 - 2014 F150
Mar 28, 2011 07:12 PM
Wizardvette
1997 - 2003 F150
Mar 7, 2005 06:28 PM
