Turning up pump 6.9
Old Sep 7, 2018 | 08:16 PM
Dan656's Avatar
Dan656
Turning up pump 6.9
Ive been looking to turn up the pump on my 6.9 and saw people saying to run a pyro gauge. Is a pyro gauge just an egt gauge? And do I really need it if I only turn it up 1/4? And my truck will spit quite a bit of black smoke if I take off in second wthout reving up the truck and just letting off clutch normally (not burning or riding it) So did they smoke from the factory or is my pump already turned up?
Old Sep 7, 2018 | 11:08 PM
genscripter's Avatar
genscripter
Do you have a turbo?
A pyro is AKA a EGT gauge
1/4 flat? Probably wouldn't affect much. The bare minimum to notice anything would be a half flat, and even then, it might not be noticeable.
If your truck is already coal rolling, then I wouldn't turn up your pump more.
I think your pump is already turned up by whoever serviced the IP last.
Why are turning it up? Are you trying to eek out some more power? If you are already smoking at initial acceleration, then you are pretty much tuned to the best position of the fuel screw. If you want more power, you should time your IP instead of turning it up. You could have it mis-timed, which would lead to some smoking or just inefficiency and lack of power.
And if you are running a turbo and turned-up IP, then you should definitely have a pyro. You are just asking for engine problems if you exceed 1200 deg F in your manifold.
Old Sep 8, 2018 | 01:02 AM
Macrobb's Avatar
Macrobb
With a N/A engine, you want to turn /down/ the fuel until you just get the slightest haze at full throttle, high RPM. Too much fuel = high EGTs, lessened motor life because of it, lower fuel economy, and at extreme overfueling, you'll actually make /less/ power.
The solution for this problem, of course, is a turbo. Add a turbo, then add fuel to match. With a 6.9, you either add headstuds or limit your boost to around 6 psi... which is still worth a good 50% more HP than stock.
Old Sep 8, 2018 | 03:55 PM
genscripter
I don't think it would add 50% more HP than stock. From what I read, the IDIT's got only a handful more HP with the turbo, but the substantial increase was in the improved torque.
Regardless, If the OP truly is an NA IDI, then adding a turbo would be good regardless of the minor HP/major TQ improvement.
Old Sep 9, 2018 | 09:27 AM
RaymondIV's Avatar
RaymondIV
Right, both ATS and Banks advertised about a 30% HP gain. However, the factory IDIT HP rating was somewhat misleading because during that era insurance companies were basing premiums on HP ratings so the auto/truck industry were stating HP on the low side according to the automotive mags. But the Ford factory turbos (ATS) were derated due to the small turbo outlet and smaller exhaust system. The exhaust system directly from ATS was a 3", with straight through muffler and Ford factory turbos were only 2 1/2.
Old Sep 9, 2018 | 10:27 AM
Macrobb's Avatar
Macrobb
Yes, it will. If you just slap a turbo on a stock motor, you'll get basically the same HP and torque as before... because you aren't burning any more fuel.
This is what Ford did with the IDIT.
Take that same kit, crank the IP fuel screw up and you can easily add that 50% more HP(Stock being best case around 125 on the dyno(seen 85 before on a N/A bricknose), 190-200 being typical for a cranked factory turbo/stock IP setup*).
Now, less boost may or may not get you to that 190-200 number, though I did that with a Banks setup at 7-ish PSI last year. It looks like the pump runs out of fuel at the top end before being able to use a whole 15 or whatever.
*Note:
I was just at Hunting 4 Horsepower yesterday. We had a couple IDIs run, including at least one 'factory turbo' swap/pump crank on a bricknose. He put down 196 on the dyno.
This dyno is the same one that had been putting out low numbers all day due to not loading the trucks sufficiently, so the numbers could be on the low side depending.
Old Sep 10, 2018 | 12:50 PM
hairyboxnoogle's Avatar
hairyboxnoogle
If its NA, turning up the pump wont get you anything, just lower fuel mileage and it will smoke.
Old Sep 10, 2018 | 01:00 PM
RaymondIV's Avatar
RaymondIV
Genscripter, FYI, dug out my old info direct from ATS, with all their R&D they say with their turbo system and the IP turned up 1 1/2 flats, which is their recommendation, they showed a HP gain of 47 horsepower. Having personally experienced a "before and after" that sounds about right to me. Of course as you know a turbo doesn't put out big time power unless it's working hard pulling a heavy load causing the exhaust gas volume to drastically increase.
Old Sep 10, 2018 | 10:09 PM
hairyboxnoogle
Thats funny Raymond, i was looking through some ATS paperwork, and the later ones they dont even recommend turning up the fuel screw, only adjusting the torque screw until you get a haze blipping the throttle. They even send a little piece of tinted lexan for reference lol.
IMO, if you have a turbo and youre turning up the fuel, max it out, its going to go there anyway because, well who doesnt want more power. Save yourself the work of doing it twice.
Old Sep 10, 2018 | 10:21 PM
Macrobb's Avatar
Macrobb
Yup.
Don't forget the torque screw(if there is one) - that's a major top-end drain(On the dyno last year I dyno'd a maxed pump rig at 150-ish HP; backed the torque screw out 1/4" to completely disable it and it laid down 200 a couple hours later). With the torque screw at stock position, it'll smoke badly flooring it at idle, but pull fuel at the top end.
Old Sep 11, 2018 | 08:31 AM
RaymondIV's Avatar
RaymondIV
My info IS for the late model ATS, the 093, same as came on the '93-94's from the factory. Can't remember which years the pumps had the torque screws but it's not mentioned in my pump adjustment info and I don't have a torque screw anyway. They do say turn it up 1 1/2, (the max WOT fuel setting, not torque screw) then check with the lexan smoke plate which I still have also. The light truck shop owner where I bought my kit said I got one of the first 093 kits available in the western states. That's when ATS was in Murray, UT, got to talk to the owner and founder a couple times on the phone. Maybe the IP's with torque screws came out '92 or later?
Old Sep 11, 2018 | 03:15 PM
hairyboxnoogle
The 093 kit came out in 93, the 088 in 88, and 085 in 85. Pumps with torque screws started somewhere in the 92 model year as rumor goes. My 92 had serpentine belts, but no torque screw. I dont know if they started when the turbos were an option or when.
Old Sep 12, 2018 | 09:42 PM
cadunkle's Avatar
cadunkle
You need a pyro. My old 6.9 would be at piston melting temperatures unloaded up steep hills, and that was with a turbo. It would be worse with no turbo. Towing and if I had no pyro and didn't have a feel for what was safe from driving by the pyro I would have melted pistons long before it lifted a head from a higher output pump and more boost. Driving by the pyro I got 4 years out of that engine before it failed, an inevitability with factory head bolts.
Also there is such a thing as too much fuel, likely the case if it's already smokey. With a high output pump you'll find giving it too much fuel at a low RPM or boost and it'll accelerate faster if you back out of it a bit until it's getting enough air to burn the additional fuel. In extreme cases with the really high output pumps you can stall the engine from too much fuel.
Old Sep 23, 2018 | 10:46 PM
Dan656's Avatar
Dan656
Okay, I do not have a turbo on right now but I am looking to put one on. If my truck already smokes some should I still turn up fuel? Is there anyway to know how much the last guy turned it?
Old Sep 24, 2018 | 12:44 PM
genscripter
Don't turn it up if it already smokes. If anything and considering you don't know your EGT's, you should probably turn it down a half flat to make sure you aren't exceeding the high egt's that can cause long term engine damage.
As far as I know, I don't know how to determine the current fuel screw orientation. It's just a hex allen key, so it's anybody's guess how much it's turned up.
