Master Cylinder Gasket
The only one I found for my truck are from LMC but still not sure because their item number 45-3621 says for 2WD
and 4WD F150 77-79, Bronco 78-79 and F250 77-79. My Truck is made 1976 but model year 1977 and I am not
100% sure it's the original MC either. Can anyone help me out here with some info? My cap, measured upside
down from edge to edge is 85x160mm. Maybe Ford still have some for sale? Thanks!
on
This could be it :
https://www.rockauto.com/en/moreinfo...125964&jsn=630
Or, assuming the bore size is the same, you could get rid of the nasty OE master cylinder completely (with a bit of work) and replace it with this :
https://www.rockauto.com/en/moreinfo...sn=642&jsn=642
HoustonDave. I live above the Arctic Circle in Sweden. If I ever find a "Help Section" up here,
it's probably going to include Absolut Vodka and Shotguns with Ammo!!!
I will call a part store for american classics tomorrow, otherwise I will buy from U.S but I am still not
sure what to order. I tried google the part nr. I got from NumberDummy ( D5UZ2167C)
and I also checked the suggestion from FMJ. (Dorman 42075) but if I make a search on
the Dorman website they say the part nr. 42075 dont fit a F150-77???
Yes, sometimes it's a little complicated to get the right parts over here but thanks to you guys it's a lot easier.
I could not carry out this without all great FTE members. You answered hundreds of my questions, showed me
a lot of Pictures with explanations and you have even sent me new and used parts.
Thank you so much ! ! ! !
Matt
Junior.trapper
07-16-2018 01:52 PM
Planejet42
04-11-2017 12:12 PM
dancraig
17
02-09-2011 10:11 PM
wilmac150
03-03-2008 07:35 PM
