Help finding replacement master cylinder gasket
Old Apr 9, 2017 | 07:18 PM
Planejet42's Avatar
Planejet42
I'm trying to find a replacement master cylinder gasket. The ones I've seen offered by everyone online have incorrect indent orientations. I purchased the Dorman 42069 gasket, but it didn't fit at all. Pictured is my master cylinder.
Old Apr 9, 2017 | 11:08 PM
orich's Avatar
orich
Buy a new lid and be done with it. Or replace the whole M/C
Orich
Old Apr 10, 2017 | 05:53 AM
Salty Dog's Avatar
Salty Dog
x2. Keep the old one in case you need to double them up.
Old Apr 10, 2017 | 12:35 PM
JEFFFAFA's Avatar
JEFFFAFA
Ford part number was C7AZ2167B. Replaced by D1FZ2167A. Replaced by D1FZ2167B. Right now there is this one on Evilbay dirt cheap.
5 results for D1FZ2167B
D1FZ2167B:
Items in search results
Old Apr 11, 2017 | 10:25 AM
CougarJohn's Avatar
CougarJohn
Plane, methinks your problems go deeper than a gasket. Your brake system is full of water. Brake fluid does that, absorbs water.
You should bleed all brake cylinders and flush the system. Pull the boots back and look for leaking fluid. If you can't do that, at least suck out the master cylinder with a suction gun or wifey's turkey baster. Wipe the bottom of the master cylinder clean. Repeat it at every oil change.
I suspect you have corroded bores in the wheel and master cylinders.
Good luck.
Old Apr 11, 2017 | 12:12 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Planejet42, off subject but what are those round school bell looking things hanging off your inner fender?
Junior.trapper
Jul 16, 2018 01:52 PM
dancraig
17
Feb 9, 2011 10:11 PM
M6EV139445
Nov 9, 2006 03:27 PM
imlowr2
May 21, 2005 11:12 PM
j-md
Apr 6, 2005 03:38 AM
