FRONT DIFFERENTIAL CLUNK
Old Sep 7, 2018 | 03:08 AM
7lug 8200's Avatar
7lug 8200
DRIVERS SIDE MOUNTING FLANGE HAS END PLAY
Old Sep 7, 2018 | 10:12 AM
alloro's Avatar
alloro
Is that supposed to be a question or a statement?
Old Sep 7, 2018 | 08:36 PM
steve(ill)'s Avatar
steve(ill)
you would expect some end shake.. You would not expect up and down play on the shaft. If you have a "clunk" inside, it might be related to the 4 x 4 engagement.. Vacuum operated piston strokes the engagement rod/ pin... make sure it is free and easily moves from the outside..
Old Sep 8, 2018 | 05:46 AM
7lug 8200's Avatar
7lug 8200
Passenger side doesn't have any play, just drivers side. when I drive over small bumps I can hear the clunk. it pushes the CVC joint in. do I have to get inside the diff? to work on it, or should I just let it ride for awhile and see if it gets worse? it isn't leaking. Thank you for response
Old Sep 13, 2018 | 11:25 PM
7lug 8200's Avatar
7lug 8200
IT IS BOTH, THAT IS WHAT IT IS DOING AND SHOULD IT HAVE THAT MUCH PLAY? THANK YOU
Old Sep 13, 2018 | 11:27 PM
7lug 8200's Avatar
7lug 8200
NO IT DOES IT IN 2 WD, IT IS THE LEFT AXLE SHAFT. THANK YOU FOR YOUR ANSWER
jeffmfly1
Mar 3, 2010 07:49 AM
sticks25
1978 - 1996 Big Bronco
May 16, 2008 10:30 PM
swervin22
13
Jul 27, 2007 04:35 PM
tvvbsn
1997 - 2003 F150
Nov 2, 2004 09:52 PM
Stangfire
1997 - 2003 F150
Apr 20, 2004 08:14 AM
