Sponsored by: Real Truck
V10 intermittent starting problem
Old Sep 5, 2018 | 10:51 AM
talonpilot's Avatar
talonpilot
i have a 2015 V10 on my F53 RV chassis. Over the past year I have had an intermittent problem starting the engine...most often when outside temp is below 60 degrees, but also experienced it this past weekend in 85+degrees after driving for 2 hours.
Here’s what I am experiencing: When I try to start, if I hold the key in the start position, engine seems to start up normally but as soon as I Release the key the engine dies. If I engage the starter, and immediately release the key, the start cycle stops ( normally, the engine should/would continue the start cycle).
If I pause for 5-10 seconds and try to crank again, it will eventually start after 5 to 7 attempts.
I have had it in the the Ford dealer, but they just could not find the problem because it is so intermittent.
Any ideas?
is there an OBD2 reader I could get that could help identify a sensor or computer issue that is causing the start cycle to abort?
thanks,
Dan
c502cid
Jan 18, 2026 09:54 AM
shades556
Oct 19, 2015 05:31 PM
LimmoDriver
Apr 24, 2012 07:02 PM
lp3509
Jan 19, 2010 04:59 AM
adolphbell
Modular V10 (6.8l)
Mar 13, 2006 07:46 AM
