MAF conversion
Old Sep 4, 2018 | 08:07 PM
89_f150_mudtruck's Avatar
89_f150_mudtruck
MAF conversion
Ok so.im sure this has been asked before but iv searched and havent found a solid awnser.my truck is a 93 f150 5.0 SD truck.was auto now is manual still with the auto ecm.i have a complete 94 f150 5.0 auto MAF truck for parts.what do i need off the parts truck for the swap? And what pins do i need to change for the diffrent fireing for the injectors.the 94 is complete truck so i should have everything i need.
Old Sep 5, 2018 | 10:06 AM
Mudsport96's Avatar
Mudsport96
Move the ENTIRE maf wiring harness to the SD truck and you will need the distributor also as the ignition module wiring is different. That is the easiest way.
Old Sep 5, 2018 | 10:14 AM
89_f150_mudtruck
What about the diffrent firing order? Just wire the plugs non ho way?
Old Sep 5, 2018 | 08:23 PM
Mudsport96's Avatar
Mudsport96
Correct, also see if you have the early roller cam. If you do, you are ok on the distributor. If you dont, you will have to change distributor gears.
darkhorse2011
22
Aug 10, 2020 04:09 PM
89_f150_mudtruck
Aug 1, 2020 08:09 AM
fordf350man
May 1, 2017 08:28 AM
32-289
Mar 24, 2014 06:06 PM
laynejc
24
Apr 5, 2009 08:59 PM
