03 7.3 p1211 icp above/below desired
Old 09-04-2018, 11:46 AM
BRay09's Avatar
BRay09
BRay09 is offline
Hi all,
03 7.3 140k ish f550 rwd. Rough running at idle and doesnt seem to be down on power, except for at times. While watching icp and ipr at idle and when it's down on power, nothing is showing out of spec. Test drove with bobcat and trailer on the truck and ICP was holding around 2400 psi.
KOEO:
EBP 14.8 and 1v
ICP .32v and 53.9 psi (hot)
IPR 15%
MAP 14.1 psi
KOER at idle
EBP 14.8 and 1.03v
ICP .88v and 483.7 psi
IPR 8%
MAP 14.0
Performed cylinder contribution test and get faults for cylinders 3 and 8. When I run a buzz test all injectors sound normal, but get an idm fault and cyl 5 high/low open. TRUCK HAS A SWAMPS IDM. I swapped idms with known good. The p1298 was no longer present, but the high/low open fault moved to cylinder 3. Have not checked fuel pressure yet. Just received the adapter and will he working on that after I post. Any idea on where I should be looking ?
Old 09-04-2018, 02:59 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Following as I am currently doing my fuel pressure regulator for the same.
Old 09-04-2018, 04:34 PM
BRay09's Avatar
BRay09
BRay09 is offline
did you have low fuel pressure? I ordered the wrong fitting for my gauge. I have to go makeshift some things at home depot to make it work so I haven't checked yet.
Old 09-04-2018, 05:35 PM
pirate4x4_camo
The fuel bowl threads are -4 ORB. Only place local I could find that was a hydraulic shop but riff raff and diesel oRings sell them.
Yes my fuel pressure was/is 30 psi at WOT and 50 PSI at idle.
Old 09-05-2018, 01:36 PM
BRay09's Avatar
BRay09
BRay09 is offline
Quick update. Fuel pressure at idle is 67psi and drops to 60-62psi at WOT.
Old 09-05-2018, 02:05 PM
mcnance865's Avatar
mcnance865
mcnance865 is offline
Cylinders 3 and 8 frequently show up together from what I understand.You will have good fuel pressure going into the rails, but those 2 cylinders will not get it all due to the firing order. Do you have a regulated return system?
Old 09-05-2018, 06:55 PM
pirate4x4_camo
i suppose you can cross low low fuel pressure off your list
dont know that it matters but why is ypur pressure so high ? Spec is 51 +/- 4 psi
Old 09-05-2018, 07:14 PM
pirate4x4_camo
So what’s next ? New IPR Orings and then on to injector cups ?
how does your radiator overflow tank look ? Oily film on the inside is a good sign your cups are leaking into the coolant. The plastic should be white but yellows over time, if it has black residue....there a sign.
Old 09-05-2018, 07:24 PM
BRay09's Avatar
BRay09
BRay09 is offline
I'm not sure. Could have been the gauge I guess. And i tested it at the fuel bowl test port.
Old 09-05-2018, 07:25 PM
BRay09's Avatar
BRay09
BRay09 is offline
everything on the truck is stock except for the IDM from swamps that was installed when I bought the truck.
Old 09-05-2018, 09:22 PM
pirate4x4_camo
One of the Probable causes the factory service manual list is a short in the IRP wiring circuit.
i was going through my records and I noticed a new IPR pig tail was installed a few years back when the dealer did an injector.
since Ihad it torn apart doing Turbo pedestal Orings, rebuilding the fuel pressure regulator and new IPR Orings I figured I’d take yank the harness and go through it since all the tape is unraveling ....
looks like I found at least one of my issues.
worst part is the shop used black tape so the wires were all goopy. Will solder a new with a pig tail, convoluted loom and factory cloth tape ( Tesa Cloth Loom tape ) to return it to factory fresh.
Old 09-06-2018, 06:44 AM
Tugly's Avatar
Tugly
Tugly is offline
...When I run a buzz test all injectors sound normal, but get an idm fault and cyl 5 high/low open. TRUCK HAS A SWAMPS IDM. I swapped idms with known good. The p1298 was no longer present, but the high/low open fault moved to cylinder 3....
Everybody skipped right over this. Passenger side UVCH needs attention. Good links in my signature.
Old 09-27-2018, 01:22 PM
BRay09's Avatar
BRay09
BRay09 is offline
Just a quick update. I changed the oil and threw in hot shots stictation eliminator. Stuff works well in the 6.0s so I figured, why not. Well fired then truck up and it was still loping at idle. 20mins go by and the idle returned to normal. I let it sit over night and fired it up the next morning and idle was smooth. Took it for a test drive and power was there, but a lot of black smoke in 3rd and 4th (truck is a manual). After about 50 miles or so the smoke came and went. But I noticed, cruising in 5th around 2k rpms, the turbo would spool with no further input from the pedal and I would pick up speed.
I reran injector buzz test and no longer get any injector faults. Cylinder contribution shows no faults. So I'm thinking either a mechanically failing injector or some things going on with the waste gate on the turbo. Thoughts?
fabsroman
06-11-2019 02:09 PM
goose_ss4
40
10-25-2015 01:32 AM
JOHN2001
23
01-30-2013 03:03 PM
beanhead6D5
08-03-2008 05:46 AM
John311t
34
03-29-2007 11:16 AM
Quick Reply: 03 7.3 p1211 icp above/below desired
