1978 - 1996 Big Bronco
Where to find firewall delete / plug?
Old 09-04-2018, 10:01 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
Hi all,
I'm taking the 302 out of my '85 Bronco, and replacing it with a "carb'd" 300 (Sniper EFI system). As such, I pulled out the ECU and the huge brick of wires that goes through the firewall.
Both the 300 and 302 of this era had an ECU (the 302 was fuel injected, the 300 was computer control carbureted), but the 351 was still 100% carb'd, so it had a rubber plug that filled this hole (so plugs DO exist).
Since I'm removing the ECU, I'd like to fill this massive hole, but can't find a plug anywhere for it.
The hole measures almost exactly 1.5" x 3.00".
Everything I'm finding that looks remotely close says they're either for an EB, or for a 67 - 77 pickup, and measure 1.375" x 2.875", which is too small.
Does anyone know where to find this plug?
Thanks
Old 09-07-2018, 03:02 AM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
Are those measurements of the actual OD, or where the inside compresses against the sheet metal (as there is slight overlap all around to seal)? Why not call these folks (the manufacturer, not Summit) and see if they have something: https://www.summitracing.com/parts/s...135k/overview/
Old 09-07-2018, 11:16 AM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
Originally Posted by AbandonedBronco
Hi all,
Thanks
Try Ron Francis Wiring GA-50 Has a hole in the center but is your dimensions.
https://www.ronfrancis.com/prodinfo.asp?number=GA-50
Old 09-07-2018, 11:25 AM
AbandonedBronco
This is the inner diameter of the hole, if measured side to side and top to bottom.
Thanks for the link, I'll get a hold of them and see what they have.
Old 09-07-2018, 11:26 AM
AbandonedBronco
That looks to be like the one I took out, with the wiring harness going through.
It's a last resort, since it is smaller, but still has a hole.
However, the 351 V8 equipped Broncos didn't have a wiring harness, since they had no computer, so they had a full plug with no hole. Hopefully I can track that one down.
Old 09-09-2018, 10:45 AM
BigBlue 94's Avatar
BigBlue 94
BigBlue 94 is offline
I searched for quite a while, with no luck. All, like you said, are the bit smaller one. It may actually fit fine, but you could go to the hardware store and get a .0625" thick o-ring, and slide it in the groove before putting the plug in the hole.
if you noticed the common plug size is only 1/8" small in both dimensions. That means it'll only have a 1/16" (.0625) space around the perimeter of the smallest diameter. I have to think that would work fine, no mods required.
My 96 f350 had a rubber plug on the floor but it's 2" x 3".
Old 09-10-2018, 07:01 PM
AbandonedBronco
Well, I found one in the junk yard today. Actually, I found two, but one was completely dry rotted, while the other was still nice and fresh. Both in bull nose trucks with 351s.
Part number is: E3DE-14603-BA
Nothing comes up with a search for that online, but... I have a plug in my firewall now.
Old 09-10-2018, 08:11 PM
AbandonedBronco
Here's some pictures.
I also pulled out my micrometer to get the width/height and it is, indeed 1.50" x 3.00" on the gasket inner diameter.
86 f250 4.9l
39
07-29-2022 09:22 PM
SabrinaNicole98
04-12-2019 08:27 AM
5280
05-18-2014 03:03 PM
Squiggy
Engine Swaps
09-29-2005 10:15 PM
gino93
06-06-2000 08:52 AM
Quick Reply: Where to find firewall delete / plug?
