300 inline six freeze plug problem
Old Apr 11, 2019 | 05:35 PM
SabrinaNicole98's Avatar
SabrinaNicole98
I had a weeping freeze plug, took em all out and replaced them with brass plugs and indian head sealant. first heat cycle the same one leaked, so i put red RTV over it. second heat cycle it leaked again. it’s installed correctly just hammered in, flush. does brass have to go through more than 2 heat cycles? what do you think could be the cause of this? thanks. i’m lost
Old Apr 11, 2019 | 07:50 PM
puppyf250's Avatar
puppyf250
Don't know if it is different on your motor, versus my 302. Had a freeze plug blow out on initial startup after rebuild. Couldn't properly install it due to clearance issues. So, put in an expandable freeze plug made by dorman. No issues since then. Might check into that
Old Apr 11, 2019 | 10:51 PM
SabrinaNicole98
do you put sealant on the expandables?
Old Apr 12, 2019 | 01:07 AM
88n94's Avatar
88n94
I second the suggestion on the expandable rubber plug. There should be installation instructions with the plug, the ones I used many years ago said to install them dry.
Old Apr 12, 2019 | 08:27 AM
puppyf250's Avatar
puppyf250
No sealant. Instructions say to install them dry.
ramair428cjxr7
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 31, 2018 01:31 PM
jspringator
Modular V10 (6.8l)
Oct 19, 2013 08:50 AM
sbclemens
Dec 1, 2010 05:27 PM
rhino_160
Jun 18, 2008 04:14 PM
