delete question
Old Sep 3, 2018 | 08:36 PM
walter white's Avatar
walter white
Wink delete question
hoping to buy a 2012 6.7 150k miles next week after many years of driving gassers. my son's deleted 6.7 got me hooked. I would really prefer to delete emissions but not sure i want to hear straight pipes all the time. What happens if you leave factory muffler on? is it possible to Tee pipe before a muffler so i could fashion a cable operated dump pipe? Is there any other way to quiet down the jet noises when i need to be quiet? I would plan to tune it also. would that change my options?
I know its a weird question but i like my kids truck a lot more than my neighbors do
Thanks
Old Sep 3, 2018 | 09:03 PM
UGA33's Avatar
UGA33
Run a 4" with a muffler. It will be pretty tame.
Old Sep 3, 2018 | 09:08 PM
bcg's Avatar
bcg
Mine is deleted with a muffler, I'm not sure which one, and while you can tell it's a diesel, it's not loud at all. I'd say about 1/4 the volume of my 7.3.
Old Sep 4, 2018 | 10:32 AM
Idaho F250's Avatar
Idaho F250
I hear that a 4" flo-pro (stainless) still gives that nice little rumble and some turbo whistle without being obnoxious.
Old Sep 4, 2018 | 01:42 PM
graysonp's Avatar
graysonp
There's not a traditional muffler on the 6.7L. Just the DPF/SCR which acts as one. You can't delete and leave it on.
As others have said, put a 4" exhaust and an aftermarket muffler. It will be fairly quiet.
Old Sep 4, 2018 | 08:53 PM
walter white
Thanks fellows
Old Sep 6, 2018 | 05:59 AM
RangersF250's Avatar
RangersF250
I deleted mine and left the factor DPF back in place. Slightly louder than stock and no drone.
Old Sep 6, 2018 | 07:45 AM
graysonp's Avatar
graysonp
Surely you're mistaken... You have to remove the DPF if you delete. Without a regular regen, it will get clogged completely within a couple thousand miles.
You're saying you only deleted the EGR and SCR and found a tune that still regens to keep your DPF clean, while removing the other two emissions components?
Old Sep 6, 2018 | 09:00 PM
RangersF250
Yes, poor wording on my part. I am DPF deleted but stock from the MBRP replacement pipe back.
Old Sep 7, 2018 | 08:08 AM
graysonp's Avatar
graysonp
Ok, I'm with you now. I first read that as if you were saying you put the factory DPF BACK in place.
Old Sep 7, 2018 | 09:09 AM
Overkill2's Avatar
Overkill2
There is a small resonator or muffler, which ever one it is, I don't know, on the tailpipe in the down bend of the tail pipe. I've heard of guys running their gutted "rocketship" with a 4' straight pipe through it. You have to cut it in half. Then probably weld it back together. I'm sure it could work.
Rooftop
6.7L Power Stroke Diesel
Oct 27, 2018 09:06 AM
Special Ed
Nov 11, 2011 02:09 AM
Gcrop
22
Mar 23, 2009 07:55 PM
villestrip
Jun 4, 2007 06:55 AM
jrciii56
Apr 20, 2006 11:43 AM
