My gas pedal has no spring, when I bought it the spring on it was hooked up wrong. I cannot find a pic or diagram of what spring or where it goes?
I understand it needs to be adjusted because asit is now I have the idle turned way up just to run.
Any help appreciated!
I need detailed instructions how to install spring! Hard to get my head underneath the pedal to see bottom connections!!! Also I have Holley 2300 on other end that I like to connect to my stock linkage. Will you suggest some threads to help me chose the best way to connect said parts?
If you look at the FTE threads you'll see a "More results from" option, you can click that and it will give you FTE paged exclusively. This is a good way to mine FTE for info without posting redundant questions.
Any help appreciated! https://youtu.be/v3OUhFd6c3U
I don't understand what the pedal spring and the idle turned all the way up has in common. Sounds like two different problems to me.
The OP is not asking about the throttle spring in the carb linkage.
The OP wants the spring that puts tension on the accelerator pedal, see 9760 at lower left in parts catalog pic.
