What winch do you use?
Old Sep 5, 2018 | 09:29 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I run a warn m12. It will struggle plenty with a 1978 f250 sunk in, towing it uphill, Or pull the tree down trying. ****** block it, keep a strap and chain, and remember that 12000 lbs is single line pull, so if that truck breaks a hub and needs pulled from a sticky mud hole, up hill, a 5500 lb rig just got really really heavy.
Old Sep 6, 2018 | 06:43 PM
NW 150's Avatar
NW 150
I'm having a hard time finding a winch that mounts to my bumper now other than the 8274. They all seem to be bottom mounts and not for the 10x4.5 mounting pattern.
Old Sep 6, 2018 | 09:53 PM
SlikWillie's Avatar
SlikWillie
Do you own a drill and some drill bits? Time to get creative.
Old Sep 9, 2018 | 06:14 PM
NW 150's Avatar
NW 150
I'm looking at the M series winches now from Warn. There's the M8000 which a warn rep recommended, and the M12. Should I save the money and get the M12 or would the M8 suffice since I'd be using a snatchblock as well? I know a few of you recommended the 12,000, just wanted to double check between the two options. They both seem to get good reviews. I only wheel maybe once a month, but I'd still be okay with spending a little extra and buying a quality winch made in the U.S.
Old Sep 9, 2018 | 06:52 PM
SlikWillie's Avatar
SlikWillie
Just remember, when you use a s/b not only do you double the power of the winch you also cut your line in half. So if you get stuck in a hole and the nearest tree or anchor is 60 feet away, you ain't getting out. With the M12, that anchor can be 85 feet away and you are good to go. I have literally been in this situation over a hand full of times. You will be more than happy with the bigger winch.
Old Sep 9, 2018 | 06:57 PM
SlikWillie's Avatar
SlikWillie
Just looked at the cost difference between the M8 and M12. WOW!! M8 for $650 and M12 for $1600. Really? $1000 difference? I keep looking for 12k winches. That's ridiculous.
Old Sep 9, 2018 | 08:32 PM
NW 150's Avatar
NW 150
Yea it's a pretty penny more than the M8. I was considering the standard zeon 12 which is around $1100 but I wasn't sure what the reviews were on those. Also if I used the ****** block with the M8 it'd give me 16000lbs of pulling power. I understand the drop in line speed in doing so along with the other points you made, but I can afford $600 sooner for a highly reviewed winch than the M12.
Rovernut
Offroad & 4x4
Oct 19, 2021 01:43 PM
JosieGallows
Jun 11, 2015 01:38 PM
NJBigblue77
Feb 8, 2012 09:02 PM
strokin'_tatsch
27
Feb 20, 2010 02:15 PM
fairfield86f150
Oct 19, 2007 04:55 PM
