X rocker panel replacement
Old Sep 2, 2018 | 07:03 PM
'94's Avatar
'94
I am eyeing down the barrel of replacing both rocker panels on my '04 X. BUT, I am having a hard time sourcing the parts. Inner and outer rocker panels are rusted through, and beyond repair. Does anyone have a good source for body parts? Really doesn't seem to be much out there.
I found on ebay (I know, i know) replacement oem inner panels for a same year but for a crew cab super duty. Does anyone know if the door size is the same and could be used on an X?
Don't be shy too if you have an X with no rust you would be willing to chop up and sell both rocker panels from front post to back post.
Old Sep 2, 2018 | 08:07 PM
Jeff53's Avatar
Jeff53
Mill supply
Check these guys: Mill Supply. I got patch panels for my old Outback from them. Worked fine.
Old Sep 2, 2018 | 08:19 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Rear Ex doors are not the same as F-truck rear doors.
all the parts except the rear dog leg should be available. For a dog leg you will need to cut one off an Ex or hand make it.
Old Sep 2, 2018 | 08:39 PM
'94's Avatar
'94
gotta love the labor day sale, got the right and left B post for 20 bucks less than anywhere else. Thanks!
Old Sep 2, 2018 | 08:44 PM
'94's Avatar
'94
Thanks for the heads up, I'm guessing the F truck rear door is shorter.
Since the inner rocker is flat probably wouldn't be too much of a PITA to add a little spacer
Old Sep 2, 2018 | 08:45 PM
'94's Avatar
'94
gotta love labor day sales, got both B posts for 40 bucks less than anywhere else. Thanks!
Old Sep 3, 2018 | 03:30 AM
DSMMH's Avatar
DSMMH
I had both rear door rockers replaced almost 2 years ago. The body shop that did the work said the rear rockers are no longer available, however, the fronts are. They ordered two fronts and cut them to fit the rear. Got to get the driver rocker replaced this Fall
Ed
Old Sep 3, 2018 | 09:30 AM
EXSwap's Avatar
EXSwap
These are the rears that I ordered:
Amazon Amazon
I'm going to use this adhesive instead of spot welding:
Amazon Amazon
Couple of good threads on replacement:
https://www.ford-trucks.com/forums/1...-rust-ugh.html
https://www.ford-trucks.com/forums/1...002-v10-3.html
Still haven't seen the inners done, but that'll get you the outer panels. Dig around and you'll find some more write-up's.
Old Sep 3, 2018 | 10:02 AM
IMASAP's Avatar
IMASAP
If you end up using the crew cab inner rockers, please post us a bunch of pics so we can see how they work out.
Old Sep 3, 2018 | 12:12 PM
Greenscobie86's Avatar
Greenscobie86
See my build thread. I bought SuperDuty crew cab outer rear rockers and built the rest myself. Mostly riveted and panel bonded together.
Old Sep 4, 2018 | 08:26 AM
rock2610d's Avatar
rock2610d
The inner rocker panel for crew cab is one long piece. It goes from front to rear.....just like the oem excursion inner rocker.
The change is that the crew cab inner does not match the excursion inner at the very rear/end. The excursion has a 90 degree dog leg that goes up to the rear quarter inner panel. The crew cab inner stops at cab corner.
I recommend sourcing good unrusted used inner rockers. The fit is perfect and in the end will be much less labor. Outer rockers are readily availble as are a and b pillars.
if c pillar is bad source a good rear quarter panel and splice it in. Rear quarters are cheap if you find one with damage at rear or dents in it. I got an entire rear for about $200 because there was a dent back by rear dog doors.
NOTE: by purchasing a crew cab inner and a used rear quarter (cut at mid span of rear door) you splice the 2 at mid point to get a very good result.
Old Sep 4, 2018 | 09:43 AM
'94's Avatar
'94
I would prefer to find a good unrusty donor, but that is proving to be a difficult task. I'm slowly sourcing new oem parts as I find them on the cheap, and yeah the crew cab to X conversion on the inners is sounding like it may be a last resort. I will be sure to post pics of the progress.
Old Sep 4, 2018 | 10:15 AM
rock2610d's Avatar
rock2610d
There are lots of good used quarters out there.
so many in fact you could probably match your existing color.
example: :$200
https://www.hollanderparts.com/used-auto-parts/2002/ford/excursion/rear-body/160-quarter-panel-assembly/160-03304br-right-r.,-w-o-wheel-lip-moulding/part-5184527-2303-1
I look at states west of Kansas, like this one in washington. Mine came from Oregon with zero rust on it.
the hardest part is finding one that is dented so you can get it cheaper.
rustfixer
Jan 24, 2019 11:32 AM
ymurf
Apr 19, 2018 05:45 AM
officer131
Jan 26, 2016 07:15 PM
RKraft
Feb 2, 2014 09:19 PM
aerovan
Aerostar
Mar 21, 2005 07:08 AM
