Anyone replaced their inner rocker panels? Mine is busted out and I need to replace them in order to install new running boards. I am not sure how hard it is going to be or how much has to come apart to replace them.
Yea not easy like a rocker panel. That is technically the pinch panel, where the floor, rocker and door support all come together. 4 layers of sheet steel, I dont think that anyone sells that. With some sheet metal skills and a mig welder you can replace anything, but custom fab is going to play the major role.
and most parts outlets sell them all together cheaper as a set.
X2! I'm in the middle of "re-storing" my 01' Reg cab and between LMC, Mill Supply, Ebay, and a few others there are many options. I believe "Classispartsforu" on Ebay has full kits for $200+/-.
