Rescuing another Ex from the junkyard: 2002 V10
Old 04-24-2017, 09:54 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
It looks like you had some fun! Mr. Sawzall is a great helper.
I'm thrilled to see that old hitch getting a new fresh start on your latest project. Looks great!
  #32
Old 04-24-2017, 10:21 AM
rock2610d's Avatar
rock2610d
rock2610d is offline
Great job, but I have to ask what those 2 ramps the X is pulled onto are rated for?
I'm getting a set if they are above 2500 lb each.
  #33
Old 04-24-2017, 12:22 PM
Greenscobie86's Avatar
Greenscobie86
Greenscobie86 is offline
Indeed I did Tom, fun is definitely the word I'd use to describe it.
Thanks!
I honestly wouldn't know if they're rated for that much. They were given to me years ago. I hand welded the supports on with a cheap 110 welder a couple of years ago, seem to be holding fine despite how sorry they look.
  #34
Old 04-24-2017, 12:48 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Sweet! On the road to recovery for sure now haha
I threw up in my mouth a little seeing all that rust
  #35
Old 04-24-2017, 01:05 PM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
I recommend the plastic rhino ramps. The set I have are rated at 3000 each, and don't scetch me out near as much as the steel ramps.
  #36
Old 04-25-2017, 03:10 PM
Rob Beil's Avatar
Rob Beil
Rob Beil is offline
Great Thread.
Very interested to see the work on those rusted panels...because mine look the same.
Acquired my beast from CT, so looks like the salt trucks got to her. Side steps are even coming off due to rusted brackets.
  #37
Old 04-25-2017, 06:00 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Fantastic work! Impressive rust on that receiver. How bad was the fuel tank guard rusted? I assume you got it cleaned up too. With that much damage, is the frame where all these accessories attach solid? Can't get enough crusty photos.
  #38
Old 05-01-2017, 11:09 AM
Greenscobie86
Thanks Russ!
Originally Posted by Rob Beil
Great Thread.
Work on the rust will commence soon. My guess is there will be a lot of figuring/measuring/checking the angle of the dangle/welding/priming/filling/sanding/painting in my future.
Thanks! The tank guard wasn't bad, looks way worse than it is. Didn't clean it all yet, will hit the entire truck with some chassis saver and wire brush/grinder prior once i deal with the rocker issues. Frame and the rest of the truck is solid, at least from what I could tell. I'll be sure to keep the crusty photos coming
Putting off major work ahead of me, this weekend is one of yet another small victories, and I DO mean victories.
A 2002 Ford Explorer/Mountaineer electrochroamatic rear view mirror swaps right on to the EX. Got one from eBay and was surprised at how easy it was to install, didn't even need to cut/splice any wires. Just snipped one of the guides off of the stock pigtail and she slid right on, all pinouts match up too. Success for $20!
Pics for reference, just be sure to remove the OEM mirror CAREFULLY and not crack your windshield.
Wiring lines right up as well as the pinout.
Snip off the right side of the factory pigtail for clearance onto the Explorer mirror.
Old v. New. Much better.
  #39
Old 07-12-2017, 09:01 AM
Greenscobie86
Well photobucket ransomed my images so now I'll have to find another way to host em, poop...
In other news I sold my white Ex and started driving this truck. Shortly after the rear left tire blew on the highway and murdered my OEM Ford mudflap and inner mud flap as well. Sucks..
Thankfully the vintage Pirelli Scorpion A/T spare was brand new and got me home.
Also picked up some Limited style wheels for the truck with decent 265 75 16 Firestone Transforce ATs on them.
This Saturday the bodywork starts.
  #40
Old 07-12-2017, 09:07 AM
wizkid00104's Avatar
wizkid00104
wizkid00104 is offline
I had those Scorpion tires on my Ranger when I was in college. They were awesome!
  #41
Old 07-12-2017, 11:54 AM
DidieX's Avatar
DidieX
DidieX is offline
Nice find on the rims. Are you looking to part ways with the old set? I want to get rid of my aftermarket non hub-centric set.
  #42
Old 07-28-2017, 09:14 AM
Greenscobie86
Cool tire indeed, wish i could find another new one but sadly they don't make em anymore.
Not sure what direction I am going with the wheels/tires yet but I will keep you posted sir!
Not too much in the way of updates:
Started taking off the running boards and sizing up the level of work to be done. Funny enough the rocker panels/inner rockers/supports are all fine from the back doors forward, even the rocker seam is good... Go figure. Will be making a patch panel for the dogleg area behind the doors and probably welding in angle iron to the inner rocker panel for running board mounts. Since the old boards are rusted to hell, I picked up some black tubular Smittybilt nerf bars to put on.
photos:
  #43
Old 07-29-2017, 06:02 AM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
I feel your pain on the rust. In the year I've been in CT, I've welded up and removed rust/rot from 2 trucks. This X will be my 3rd project now
My current X has the exact same rust on the rear pass door. it's not blown through yet like your pic above, but pinholes for sure. I hate beet juice and salt!
Love that color. Glad to see someone saving her
  #44
Old 07-29-2017, 06:54 AM
Matt M, PA's Avatar
Matt M, PA
Matt M, PA is offline
Great progress!! I also was glad to see how an Ex looked without the running boards. I've had a interest in the. PowerSteps for a long time...just haven't done it....so the pic without boards is a help. Anxious to see the new tubes...
I too found some slight rust beginnning on my hitch. Maybe over the winter I can remove it for paint or powder coating. How tough to just pull-replace the hitch?
  #45
Old 07-29-2017, 07:49 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
Just pulling the hitch is a pain Matt, mainly due to the two round headed bolts they used to help prevent folks from taking them off and leaving them off. You will need to drill out the round heads and replace them with hex heads for reassembly. Additionally the factory used blue thread locker that softens up with heat, using a torch right next to the gas tank is not a good idea. I would drop the tank, it pretty easy to do, 4 skid plate bolts, 2 hose clamps on the fill and vent then drop it right down on a floor jack. Once all the way down you will have two quick connects on the fuel lines to pop loose and the pump power and level sender electrical plug to undo. All of the wires and fuel lines have enough slack to drop the tank all the before undoing them. Once the tank is out of the way using heat on the thread locker is much safer and makes the hitch bolts spin so much easier. And you can now use a pipe wrench on the round heads to spin then out vs drilling them. It's a good opportunity to clean up that underbody area while you are there.
Quick Reply: Rescuing another Ex from the junkyard: 2002 V10
