Air Conditioner Troubleshooting
Old Sep 2, 2018 | 04:08 AM
CamoF-250's Avatar
CamoF-250
Friday my air conditioning seemed to work fine. Yesterday I finished up replacing the majority of my vacuum connections. In the process of routing things, I unplugged and reconnected the connector shown the the photo (image is not my truck); this is the only change I made to the ac system that I am aware of. Last night during my test drive my air conditioning never cooled at all. I checked the vacuum repair to my blend door actuator and it appears to function correctly and has vacuum. It appeared that while my AC clutch pulley was turning, the clutch was not engaged as it should be with AC on.
Need help trouble shooting the AC compressor I guess? Did I cause this or is it just coincidence?
Old Sep 2, 2018 | 10:55 AM
CamoF-250's Avatar
CamoF-250
I jumped ac clutch off the battery and it engaged. Checked fuse it was fine visually but replaced it anyways. I am not detecting any volts to the wire that plugs into the ac compressor clutch
Old Sep 2, 2018 | 11:08 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Could be a bad pin in the connector. Try plugging it again and see if it helps.
Old Sep 2, 2018 | 08:52 PM
CamoF-250's Avatar
CamoF-250
It the low pressure switch it’s self. Bad luck or bad timing.
Old Sep 3, 2018 | 07:39 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Did you get it fixed? You should be able to change that switch without evacuating the system.
What did you use to replace your vacuum lines?
Old Sep 3, 2018 | 06:59 PM
CamoF-250's Avatar
CamoF-250
Yes, it is fixed and which line? Its been a mix of windshield washer/vacuum line, braided transmission cooler and heater core lines; frankly like the braided stuff a lot more but it costs more. Can't track cost though on a project like this, you'll never start it. The low pressure switch leaked for a quick second say the 2nd thread when removing switch and the 2nd to last when tightening (same spot). No big deal on that, "AC Blow Cold" now!. As far as vacuum goes I have the short piece of line to that transmission controller thing and the line from the cruise control module to the pressure release on the brake pedal assembly left for tomorrow afternoon.
To troubleshoot the switch, remove the pig tail. On the pig tail jump the two pins, if the AC begins to blow cold you've either got a bad switch or maybe low pressure in you ac system. I'm sure there are smarter things to do line verify voltage and check resistance but I'll gamble 12.99 (auto zone) on a switch to save that head ache and amount of questioning on here.
Old Sep 4, 2018 | 09:05 AM
HardScrabble
Jump those pins if you ever have to charge it from really low charge. It runs continuously when jumped and takes a charge much faster. It runs very briefly when low.
Glad you got it fixed.
I asked about the vacuum lines 'cause I keep hoping someone will come up with original style replacement vacuum lines.
Old Sep 8, 2018 | 06:57 PM
CentralCoast150's Avatar
CentralCoast150
4wd Low
Regarding replacing the vacuum lines, I bought some silicone lines through Silicone Intakes and they're pretty legit. They have almost all the matching colors to the oem vacuum lines, but I need some ideas on how to bend them 90°. Unfortunately even the company couldn't really tell me how I might achieve this. I picked up some extra rubber grommets at the junk yard in case I need to piece something together but im trying to find the cleanest look possible. My first attempt at the bend was with a lighter but the hose pinched in a bit. Still allowed flow but didn't want to chance it tearing at the pinch. A heat gun might work though I haven't had the chance to try. Anyone have any ideas?
Old Sep 10, 2018 | 10:39 AM
CamoF-250's Avatar
CamoF-250
So at work (I am an engineer) we were trying to take a silicone hose and make it 90 degrees, so here is what I did: Take wire approx. the ID of your hose and bend it to the shape you desire. Your bend must have a radius though. Now slide your hose on the wire and heat it a heat gun, a lighter may work but you’re more likely to burn your hose. After it cools, and with a little luck, once the wire is removed the hose should hold its new shape.
jwhopson
Aug 20, 2015 05:57 PM
VA250SD
May 12, 2012 11:58 AM
JIM ROLAND
60
Jun 12, 2010 09:23 AM
XBAJBUSX
21
May 27, 2010 07:08 AM
algorythm
May 29, 2007 10:34 AM
