LED Tailgate Bar
Old Dec 21, 2018 | 04:57 PM
  #31
cficare's Avatar
cficare
Originally Posted by BROWN DOG KTM
Doesn’t that wire say #2 on the plug itself ?
I bench-tested the connections to determine polarity, so pin numbers didn't mean anything after that ... and since there are only two.
Old Dec 21, 2018 | 07:55 PM
  #32
NorEasterMA's Avatar
NorEasterMA
Originally Posted by leejk
Ah ok. Now that I think about it, the pigtail is a repair kit, so makes sense it doesn’t have the full length of wire.
I found a shorter t connector similar to the magnum that I’m considering: http://www.hopkinstowingsolutions.co...ses/41154.html
I assume these types of connectors don’t make the truck think a trailer is connected?
thx
That connector likely won't work, as it draws from the trailer plug circuitry. The key different with the Magnum harness is that it is a T off of the rear tail light harness, NOT the trailer harness. There is a difference. Anything tied into the trailer circuitry causes the truck to "see" a trailer. That's the reason the Magnum harness is so popular. I had the original Magnum harness on my rack and lived with the "phantom trailer" for two months. I was one of the first to get the new Magnum harness and discuss it on here and boy was it nice to have the truck back to normal!
Old Dec 21, 2018 | 08:23 PM
  #33
leejk's Avatar
leejk
Actually it does work fine. Local parts store had it and let me try it. It doesn’t affect the truck thinking there’s a trailer connected all the time, and gives me power when the park lights are on. Works great if you don’t need a long harness.
Old Dec 22, 2018 | 09:02 PM
  #34
BROWN DOG KTM's Avatar
BROWN DOG KTM
I got my OEM LED light installed today with the wiring pigtail receiving power from pass side tag lamp red / blue wire.
The right wire (pass side) was the ground wire & it’s #2 on the plastic plug that connects to the lamp.
Old Dec 27, 2018 | 02:48 PM
  #35
ELMIII's Avatar
ELMIII
Do you have the part number for the t-harness from Magnum for your XLT?
Old Dec 27, 2018 | 03:47 PM
  #36
chipssuperduty's Avatar
chipssuperduty
Go to Magnum Truck Racks as described in post #11 in this thread. Scroll down until you see the modular 10' harness. Click on that and enter your truck info where it tells you. I have not checked that site lately, but everything was straight forward. Easy to deal with.works as described and I have not had any trailer connected messages. It is not cheap but simple install. I think it is a great way to add items without splicing into vehicle wiring. Just plug and go.
Old Dec 27, 2018 | 03:58 PM
  #37
ELMIII's Avatar
ELMIII
Thank You, got it ordered!
Old Jun 27, 2022 | 04:10 PM
  #38
Wisesuperduty's Avatar
Wisesuperduty
Trailering
looks like the harness is now $350 !!
1carguy
2015 - 2020 F150
Jan 23, 2018 05:00 PM
sstemy
2009 - 2014 F150
Aug 19, 2016 10:28 AM
Lizard XJ
Sep 16, 2007 06:06 PM
Myvstar650
All Things Towing
Mar 27, 2002 03:12 PM
