LED Tailgate Bar
Old Sep 5, 2018 | 10:44 AM
KEVPOPPAPUMP's Avatar
KEVPOPPAPUMP
Originally Posted by chipssuperduty
I agree. I think that is just the pigtail. I wanted something that I could just plug in and tap the wires on the magnum harness. I am planning on adding other lights so the magnum harness works perfect for what I want to do.
I ordered the Magnum harness and Ford factory tailgate bar like yours. Being as though the harness is 10’ long and is only run maybe a foot if that, did you roll up the excess and zip tie up around the spare?
Old Sep 5, 2018 | 07:31 PM
chipssuperduty's Avatar
chipssuperduty
I tucked mine up along the passenger side frame and zip tied it. I extended the wires from the lightbar pigtail. I put them in a wire loom over to the passenger side and tapped the wire from the magnum harness. I just wanted to keep the harness at length until I am done adding things.
Old Sep 6, 2018 | 07:37 AM
F250Smitty's Avatar
F250Smitty
If someone comes up with the Harness Part number could you post it please and thank you.
Old Sep 6, 2018 | 09:59 AM
Sunny11's Avatar
Sunny11
https://magnumtruckracks.com/shop/tr...n-wire-harness
Old Sep 7, 2018 | 11:17 AM
Desert Dave's Avatar
Desert Dave
I'm interested in the Ford part # on the actual tail gate light bar found on the DRW Super Duty.
thanks,
D2
Old Sep 7, 2018 | 01:38 PM
chipssuperduty
The 3 light LED lightbar is part #HC3Z-13A613-C and the pigtail is part #8U2Z-14S411-AAC
The lightbar goes in place of the blank plate. There is an opening behind the blank plate for the pigtail wire to pass thru.
Old Sep 7, 2018 | 04:25 PM
Desert Dave
Thanks very much for the part numbers!
D2
Old Sep 8, 2018 | 02:58 PM
cficare's Avatar
cficare
Installed mine today with an OEM pigtail (PN: #8U2Z-14S411-AAC) connected to the license plate light. The two pigtail wires are color-coded the same ... no way to differentiate between positive and ground. I determined polarity by bench-testing it and they will not work if wired backwards. I do not know if the 3-light marker bars are all wired the same from the manufacturer, but FWIW the passenger side pin on mine was the ground connection.
Old Sep 9, 2018 | 06:18 PM
gravedgr's Avatar
gravedgr
I might do this. What's the price from Ford for the two pieces?
Old Sep 9, 2018 | 07:41 PM
chipssuperduty
Hey gravedgr,
I just checked on TascaParts.com and the lightbar is about $67 and the pigtail almost $15. I do not know what shipping would be. I have purchased several items from Nate at Fairway Ford in Ohio. Its a starting point. See if your local dealer can match or beat what you see online. Good luck. Hope it helps.
Old Sep 9, 2018 | 09:43 PM
gravedgr's Avatar
gravedgr
Hey gravedgr,
Awesome, thanks!
Old Oct 6, 2018 | 02:50 PM
leejk's Avatar
leejk
Hi,
I appreciate the info here on this. I got the two Ford parts, the light and the pigtail. Today I got under there and took a look, but don’t really see anything close by to tie into that the pigtail would reach. Being it is a OEM pigtail I thought it’d be long enough already to tie into existing, but don’t see anything. Would anyone happen to have a few pics of their install using the OEM pigtail?
thx
Old Oct 6, 2018 | 04:22 PM
  #28
chipssuperduty
You will have to add a length of wire from pigtail to where you want to tie in. A no expense option is to tie into the license plate light. You will have to check to see which is the power wire and which one is ground. It matters on the lightbar. I put mine in a wire loom and it is taped so you can't see any wires. I used a Magnum Harness as listed above because I wanted to add other lights as well and did not want to make splices in the trucks harness.
Old Oct 6, 2018 | 06:03 PM
  #29
leejk's Avatar
leejk
Ah ok. Now that I think about it, the pigtail is a repair kit, so makes sense it doesn’t have the full length of wire.
I found a shorter t connector similar to the magnum that I’m considering: http://www.hopkinstowingsolutions.co...ses/41154.html
I assume these types of connectors don’t make the truck think a trailer is connected?
thx
Old Dec 21, 2018 | 11:30 AM
  #30
BROWN DOG KTM's Avatar
BROWN DOG KTM
Originally Posted by cficare
... OEM pigtail (PN: #8U2Z-14S411-AAC) ... FWIW the passenger side pin on mine was the ground connection.
Doesn’t that wire say #2 on the plug itself ?
