Sponsored by: Real Truck
Snow Tire Setup
Old Aug 30, 2018 | 08:14 AM
Ford091214's Avatar
Ford091214
Snow Tire Setup
2015 F250 XLT 4x4 CCLB 6.2; All Stock
Looking to set myself up with a set of studded snows. Current tires are 275/65R18. I found a set of 265/70R17 for $150 each. I found an eBay listing for a set of 17x7 1/2, 8 on 170MM rims for $50 each.
There any reason this setup won't work? I concern of mine is the brake clearance from 18s to 17s, but I've read I should be ok. The rims seem a bit narrow as well too. Any issue there? Thanks.
Old Aug 30, 2018 | 09:03 AM
Batman7777's Avatar
Batman7777
My choice of Winter (All Season) tires that can be studded are the Goodyear Duratrac.
I've tried several including three sets of BFG All Terrain and found the Duratrac's to be the best in Winter on Snow and Ice.
BFG's would snow pack solid in the tread and not clean out. They then become a slick with no grip.
Old Aug 30, 2018 | 09:23 AM
Ford091214's Avatar
Ford091214
I was more concerned about 17s fitting on the truck. Haven't done much research on which tires to run.
Old Aug 30, 2018 | 09:32 AM
'65Ford's Avatar
'65Ford
One thing to check (cause I don't know) is if the 17 inch will also be compatible with your truck's stability program and anti lock brakes. Trucks/cars today are sometimes too smart for their own good.
Old Aug 30, 2018 | 09:35 AM
Ford091214's Avatar
Ford091214
That's something I haven't thought of either. Which is why I was hesitant on the 17s. 17s are going to be much cheaper though.
Old Aug 30, 2018 | 11:14 AM
seville009's Avatar
seville009
I wouldn’t hesitate to use the 17’s ( my stock tires are 18”)
just curious how the brakes would be affected by a change in tire size though. I’m no mechanic, but nothing in the brakes change when the tire is changed, and you’re going down a bit in tire size.
I’d vote for the studded Duratracs too (even though you’re not asking). I use them for plowing; they’re great.
Old Aug 30, 2018 | 12:28 PM
Ford091214's Avatar
Ford091214
Rubbing the calipers.
Old Aug 31, 2018 | 09:27 AM
dmarch's Avatar
dmarch
Nokian Hakkapelita LT2’s. Best snow and ice tire there is. Run the stock size. I’m in Montana at 6300’ elevation and have run them on all my vehicles for years.
Old Aug 31, 2018 | 09:56 AM
Batman7777's Avatar
Batman7777
Nokian used to make Bridgestone Winter tires. Now Bridgestone makes their own.
They are an excellent Winter tire.
The BEST Winter tire I've used is the Blizzak, but they are Winter only. I would demonstrate the stopping and steering ability of Blizzak's in a school parking lot covered with ice and snow.
People would think we were almost on dry pavement. They were very impressive, but..... Winter Only.... They wear out fast..
Duratrac's are year round.
Old Aug 31, 2018 | 08:43 PM
SuperDutyScaler's Avatar
SuperDutyScaler
17 inch wheel will fit with no issues, that year truck was offered with 17's, 18's or 20's ALL with the same size brakes so no issues like I said. And a quality snow tire will actually pack with snow becasue snow in the tread actually gives you traction on snow and or ice
snelldawg
Aug 14, 2018 07:57 PM
wildcat99
2004 - 2008 F150
Dec 11, 2009 09:59 PM
LLOYDJOHN
33
Oct 24, 2007 10:24 PM
Pocket
Oct 11, 2005 07:15 PM
Primered86XLT
Mar 7, 2004 02:16 PM
