Rod on turbo that increases boost.
Yeah be careful about messing with the rod. Mine was swedged on there hard, and you can tear the membrane in the canister if just cranking on it like Hans Hamhands.
Another option is pull the red line off the canister and stick it on a convenient bolt. It will then open at it's max setting regardless of signal sent via vacuum.
Turbo Master or equivalent will allow you to dial it in, but to me that's too much effort for minimal reward.
Big_Man_Brad
12-21-2007 06:09 PM
